Buying Some 18" IROC replicas so tire size on these 8.5 rims inch?
Old Jan 12, 2014 | 04:29 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
88 Iroc lowered 1.75 and what would you go with. I looked and looked till i'm sick... these are my tire choices for 18x8.5 with 4.75 BS
A. 215/35/18
B. 225/40/18
C. 235/40/18
D. 225/45/18
Thanks for your help before i dump the cash and dont like the way they sit
Old Jan 12, 2014 | 04:25 PM
mjdavis68's Avatar
Re: Buying Some 18" IROC replicas so tire size?
anyone help me with this?
Old Jan 12, 2014 | 07:12 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Try the searching , fairly easy question , that's why people are not posting..
Are sure there 8.5 iirc they only come in 8" with
None of those tires you posted are ideal size for that wheel
Old Jan 12, 2014 | 11:50 PM
mjdavis68's Avatar
right here....http://www.ebay.com/itm/231108188370
Old Jan 13, 2014 | 07:09 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Buying Some 18" IROC replicas so tire size on these 8.5 rims inch?
245-40-18 is the size you want...
Old Jan 13, 2014 | 10:30 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Originally Posted by mjdavis68
Ahh I see now I see where you got the sizes from..yea those tire sizes are for other fitments ..
yea ideal size posted above
Issue with the tire sizes above is that you will get a stretch looked , smaller contact patch , and overall diameter would be off compared to stock wheel/tires
Old Jan 13, 2014 | 06:07 PM
mjdavis68's Avatar
oh,. i don't want the stupid skate board look....so now what?
sorry to keep asking, i'm just looking for a comforting opinion
Old Jan 13, 2014 | 07:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Like said before 245/40/18 is what you need
Old Jan 17, 2014 | 04:58 AM
Mr. IROC-Z's Avatar
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
I'd go 245/45/18. The taller sidewall looks nicer. I have that size on my front wheels now...
Old Jan 17, 2014 | 07:31 AM
paul_huryk's Avatar
While it is a readily available size, 245-45-18 is going to change a few things:
1) It will be 1" taller than stock or 245-40-18, causing your speedo to read wrong, plus the extra diameter may have your car bottoming out or rubbing more likely.
2) You are going to be swinging a lot of weight in each corner for only a 245 width tire - with reproduction IROCs and a 245-45-18 tire, it most probably will weigh more than a 275-40-17 tire on a 17" x 9.5" wheel.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
wruiz
Aug 13, 2015 09:07 PM
mustangman65_79
Aug 11, 2015 03:17 PM
knight72
Aug 10, 2015 09:32 PM
