18" and 19" c6 fitment help
Old Jan 31, 2020 | 12:03 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Will OEM c6 18 and 19s fit without mods? Im running a 4th gen rear and ls1 front brakes stock ride height. From what Ive found Ill need 2" spacers up front. Tires on them are 245/40/18 and 285/35/19. My car is freshly painted I cant do any fender mods at this point so If they wont fit ill pass on them..
Old Jan 31, 2020 | 12:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 18" and 19" c6 fitment help
Rear might need additional spacer if 79mm offset 10” wide wheels. Some inner well mods in the front portion of the rear wells needed too
Old Jan 31, 2020 | 01:04 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will need spacers for the rear too. I am not sure what thickness, I have C6 wheels as rollers right now and I think I have a 1.25" rear spacer.
Old Jan 31, 2020 | 01:11 PM
seiplentz's Avatar
Car: 85 Z28
Even with the 4th gen rear?
Orr yes they 10" wide. Would it just be a miner BFH to the front of the wells?
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I have a hubcentric 5/8 slip on rear spacer on my 4th gen spec rear and the fit is perfect but does need well mods with 295’s. Idk about 285’s
yes just hammering in a corner
without the spacer may need alot more hammering and may need to cut the bumpstop
Old Jan 31, 2020 | 01:16 PM
seiplentz's Avatar
Car: 85 Z28
Thanks!! These wheels I found are a steal with damn near new tires on them. Tough to pass up on but wanted to make sure they would fit without much agg considering its painted already..
Old Jan 31, 2020 | 01:18 PM
seiplentz's Avatar
Car: 85 Z28
Where did you order your spacer from?
Old Jan 31, 2020 | 05:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Skulte but they dont do them anymkre. Might even be out of business
Old Feb 11, 2020 | 09:31 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
You'll want a 1" spacer in the rear, and a 2" up front. I've got C6 wheels with a 95 Z28 rear.
seiplentz
Wheels and Tires
Aug 11, 2019 05:32 PM
Mailman818
Southern California Area
Jul 20, 2011 05:09 PM
ZONES89RS
Aug 24, 2007 06:43 PM
crrllmich
Jun 27, 2006 12:08 PM
BOTTLEDZ28
May 13, 2002 08:34 AM
