3in Exhaust....We were so right!!!! :P
Old May 26, 2005 | 10:48 PM
redraif's Avatar
Transmission: Th700R4
So the results are in...
What did the custom 2.5 inch (primaries) mandrel bent y-pipe to a single 3inch pipe with 3in cut out to 3in Magnaflow convertor to Flowmaster's American Thunder mandrel bent exhaust system do for RAIF's performance (3.4l)????
Well some said it would kill the torque...
>>>WRONG!
Others said the exhaust system is too long from the start and a 3in would cause too much backpressure loss causing reversion & a lack of the proper scavaging effect...
(hence my old 2.25 crimp bent system initially gaining HP and torque when the cut out was opened. See an ideal system would see no difference with the cut out removed because it is flowing optimally!)
>>>WRONG AGAIN!
And others said is would sound like crap...
>>>WRONG! WRONG! WRONG!
(The car's sound impressed a VIPER guy with a 1000HP VIPER. Heck, the whole dyno shop thought I swapped in an V-8!)
Check out the gains yourself....
The graph is comparing my best pull with the cut out closed with the old crimp bent 2.25in system with the cut out closed!
Max Power = 141.3 @ rear wheels (+20%) = 169.56hp @ the fly wheel
Max Torque = 221.3 @ rear wheels (+20%) = 265.56ft-lbs @ the fly wheel
This puts me at 9hp over stock 3.4 numbers...
(Granted the 2.8 plenum probably is more restrictive then the 3.4's & my heads are 160,000 miles w/o a valve job!)
My torque is 65.56 over stock 3.4 numbers!
My gains with the 3inch exhaust over the 2.25...
Horsepower gains...15.4HP
Torque gains...18.2ft/lbs
And when the car was uncapped...I had instead 140hp and 222TQ...so esentially the same...meaning the system is very efficient!
Edit: making the custom exhaust changes more clear (what Dean pointed out below)
Old May 26, 2005 | 11:01 PM
LT1guy's Avatar
Car: 1987 Trans Am
Needless to say, we're pretty happy with the numbers for now, esp considering the custom chip isn't in yet and we're still waiting on the new intake! After that, we'll be doing a valve job and a few other tricks to the heads, 1.6 rockers, installing the MSD Digital 6 ignition and new fuel pump, and maybe a few other surprises.
For those of you that have heard Redraif's car before, you'll probably agree that it sounded pretty good for a V6...but it sounds SO MUCH BETTER NOW! None of the gurgling, popping, etc you often find on a car with a too-large exhaust. I had hoped that we weren't going too far, and I'm really glad we went through with it, esp the larger y-pipe.
Old May 26, 2005 | 11:18 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Old May 27, 2005 | 12:40 AM
Doward's Avatar
LOL, yes, but aren't you running a modified 3.4L motor?
A stock 2.8L will hurt from a 3"
Old May 27, 2005 | 05:56 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
nice.
Old May 27, 2005 | 07:55 AM
LT1guy's Avatar
Car: 1987 Trans Am
Most here thought it would hurt a modified 3.4 too...I even had my doubts, but as soon as I heard it I knew we had done the right thing!
Old May 27, 2005 | 09:06 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
very nice!
Old May 27, 2005 | 09:19 AM
redraif's Avatar
Of course, but that still did not stop everyone, including you, from saying it would be too much for my car and hurt the performance... so see you are not the only one who can benifit from a 3in sys...lol...
AM91 and I are doing just fine with ours!
So when are you going to jump in the 3in club Doward? My results should totally prove you could use it!
Old May 27, 2005 | 09:23 AM
redraif's Avatar
I remember we got in a good debate one night over what to do first...I kept saying exhaust...Joe said the tune was the real problem...it turn out fate got the exhaust done before the chip arrived! And the exhaust alone was a huge gain. I'm glad it worked out this way. It was going to bug me till no end to know what a real system would do on the car, despite the other weak areas! Now I know...
now to go torture the exhaust forum!
Old May 27, 2005 | 10:11 AM
KED85's Avatar
That is very impressive.
Very Impressive.
Old May 27, 2005 | 10:22 AM
Car: 91 Camaro
I think Doward is running 3".
Old May 27, 2005 | 10:28 AM
Doward's Avatar
I've been running a 3" mandrel exhaust for over 2 years now
All in preperation for the turbo... and yes, it DID reduce performance vs running stock. (17.224 vs 17.071)
I'm glad you were able to make better use of it, vs stock... You were running all stock, right? I think the fact that your increase in power increased with rpms, should show you that as you pushed more air through it, the system came more 'in line' in regards to exhaust velocity.
I do think a properly set up 2.75" exhaust will do you better than the 3". Although, unless you were to bring your car to me, and let me build you a system, we won't exactly ever know :P
All in all, that's a nice healthy increase, on a very healthy motor. I only ask that we not turn this into a 'every motor must have a 3" exhaust!' debate.
143/221, hmm? That's damn respectable! Plenty of torque in that motor!
Old May 27, 2005 | 10:47 AM
redraif's Avatar
Doward...I don't know how I missed that you were running the 3in system... It must have been the way I read you post before...oh well...Sorry! So now I'm the 3rd in the club I guess! You change over before or after the turbo? Cause I know you have been turbo tinkering for a while...
I might have gone 2.75, but when have you heard of a flowmaster 2.75 in system? Plus with us going turbo eventually its best to only do the exhaust once if you can manage it! Esp when you tally up the cost of a custom mandrel bent sys! Yikes! I would not want to do it twice!
NO, I WOULD NOT ADVOCATE A 3in FOR EVERYONE, JUST THE HIGHLY MODIFIED 3.4s and those with larger motors! 3.1s and 2.8s have to be so, so far modified for it to be benificial (AM91...& Doward's turbo) People need to understand the reason we did this is that the car is very modified, but something was holding it back... Air flow was the key in MY CASE! Thanks to an enlightening dyno run with the old system and a well placed cut out! Air both in and out are MY car's weak points! I can't wait to see what the new intake brings!
Old May 27, 2005 | 10:57 AM
Dale's Avatar
Engine: 350 S-TPI
I know my engine doesnt like the cut-out I put in it. It has more top end, but down low it is more sluggish.
I am not pleased with my choice of installing a dump.
I am pleased with the 2.5"?? dynomax.
Old May 27, 2005 | 11:11 AM
redraif's Avatar
You dynoed it Dale, to see what it really does in comparison?
I was floored when the cut out changed nothing on my dyno pull this time. Just made it louder!
I noticed I got reved at by alot of imports when I capped my 2.25 system for the week I was getting emissions done. Un capped though they try to hide! Esp with the 3in system open!
Old May 27, 2005 | 11:44 AM
LT1guy's Avatar
Car: 1987 Trans Am
My intention wasn't to make it sound like every 60 degree out there needs a 3" exhaust...far from it, just that on this particular vehicle with its combo it works, and may work as well on a similarly modified car.
The main thing I have learned over 20 years of messing with cars is that the conventional wisdom on ANY modification isn't always correct in every case. Take in what others say as far as their experience goes, but what worked on theirs won't necessarily work on yours. When I first installed the cam in Redraif's engine, most said it would kill torque...the same cam is in it today, and it did not. i didn't think a cutout would help her old setup; it helped tremendously, and gave us an idea just how bad her exhaust system really was.
The real mistakes come with the hard and fast "rules" some spout as gospel, though, esp concerning exhaust sizing and fuel delivery. There are exceptions to every rule. Back in 96, when I was starting to mod my 95Z, I was told by several "experts" that my lightly modded car (4.10 geared 9" and a few bolt ons) didn't need a larger fuel pump...the stock one would support way over the HP I was making. Well, I put in a larger one anyway and picked up 3 tenths and 5 mph!!! Unusual? Yes. But without testing, trying new ideas, and dynoing your results you really don't know, esp if you are working on something off the beaten path, like a V6 Firebird! When I first started coming here, there was very little aftermarket support for these engines, and few that had ventured very far from stock, so a lot of what we and others have done (AM, Ked, Doward, Dale, Dean, etc) has been done with very little guidance. Things are a lot easier now...there is plenty of good info here...but there is still a lot to learn. IF you have an idea, try it...if it doesn't work, take a step back, and figure out why, and come up with something else.
Old May 27, 2005 | 12:09 PM
Car: 91 Camaro
I guess now I'm not the only one who says that my car runs no different whether its full exhaust or open headers! thank you!
Old May 27, 2005 | 01:04 PM
Dale's Avatar
Engine: 350 S-TPI
Shannon, no I havent dynoed the car, the shop around here wants 150 to dyno at 3 pulls F-THAT!!! but that is full ecm scan, pipe sniffer, and the works. I love my car and building it, but I have much better things to spend 150 at this time.
I was refuring to my butt-dyno The car goes like hell around 45 and up with the dump open, but below that, its slugish.
Close the dump, I seem to have more on bottom end, and little less up top. The car is mainly driven in town from light to light, I need the torque/low end and less noise.
Joe, I didnt think I "figured" much out on these engines other then the rockers. I try what others try and post my results.
Right now I'd just be happy to figure my starter problem out
Old May 27, 2005 | 01:39 PM
redraif's Avatar
Hey Joe don't forget TomP with his helpful insights, esp on the rearend swap! Could not have done it w/o him!
Joe and I were just talking last night about how nice it is to be able to come here and post our acomplishments... help people out... share what works and does not! I know alot of my car's issues would have taken longer to solve w/o this board! Plus you all are the fuel for my fire to keep going on the 6 and not let the v-8 guys push me to the other side! I'll have one in the 82, but RAIF needs to stay v-6. Keep him different!
AM...I never knew you have the cut out and had no gains with it. If I had known that I might not have waited so long to do this!
Old May 27, 2005 | 01:50 PM
Car: 91 Camaro
i don't have a cutout but i have pulled my y-pipe out of the car at the dragstrip. i do want to put a cutout on it though (maybe 2 of them) just cause it's fun to make all the noise with it! It sounds incredible idling with open headers!!!!
Old May 27, 2005 | 02:50 PM
redraif's Avatar
I have to agree...its such a satisfiying sound. I had a crowd yesterday when I was pulling out of Joe's neighborhood...they heard the car idling with the open cut out in the drive as I dashed in for the cutout's cap for the dyno test... they came out to look and were trying to get me to light up the tires! I gae them a quick spin and took off!
Too bad you are not coming up to GA for the F-body Gathering...be nice to hear the car!
Old May 27, 2005 | 03:12 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
I'm about to put a 3" catback on my otherwise stock 3.1
lol
Old May 27, 2005 | 03:53 PM
redraif's Avatar
Expect somegurling and possible back fire if the back pressure is not enough... What are you doing about the exhaust manidfolds, y-pipe, and cat? If they stay stock you have effectively done nothing. The car can only flow as much as its smallest bend or pipe!
Old May 27, 2005 | 04:24 PM
redraif's Avatar
Question posed on another thread on camaroz28.com
Yeah ok so I jumped in on a thread where they were bashing the choice to go to a 3in on a 3.4 that did not have nitrous, a blower or and turbo...
Told them what I had here...
Someone asked... I went from a 2.25 crimp bent sys to a 3in mandrel how do I know what would have happened if I had gone with the 2.5 mandrel bend system?
Reply:
Well I have PF&E headers and their mandrel bent y-pipe was 2.5 atits exit (2in primaries into 2.5in)...it flowed to a 2.5 inch pipe then to a 2.5 inch cut out. So it was effectively a 2.5 inch system to the open cut out. I opened the cut out on a run not listed on the above dyno sheet...it is what gave the indication that I was in need of a better exhuast system.
I pulled on that run...
134HP and 207 TQ At the wheels... so if I had only gone to a 2.5 inch system and it was as effective as the cut out, I would have flowed just that on a 2.5 inch system!
So my dyno difference from a 2.25 crimp bent sys to a 2.5 decent system...
9hp gained
4ft/lbs tq gained!
So my dyno differences from a 2.5 inch system to a 3in mandrel bent sys with custom 2.5 inch primaries to a 3in (y-pipe)
7hp gained
14ft/lbs TQ gained!
As I said before... with the 3in sys I can run open with the cut out and there is essentially no difference. See a near perfect exhaust system will actually have little to no difference with a open cut out!!
Old May 28, 2005 | 12:28 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Redraif and Lt1, I am not surprised at all that you showed gain over the 2.25" factory exhaust with the 3" exhaust.
I am also not sirprised that you showed no difference under maximun rpm and HP readings under the 3" compared to the cutout. What I am surprised and would like to see the dyno results is the low down rpms and tourqe ratings on the motor with the 3" exhaust. What I am saying is that the HP output of the car at max HP readings is enough flow of a V8 5.0L motor at idle/cruising speeds so of course the max HP reading will flow the 3" fine. I am (respectfully of course) skeptical of the low down power output being max potential through the entire powerband leading up to the higher rpm flow and output.
I still dare to say that the that the lkower rpm #'s would look better and the high rpm #'s would not change with a 2.5" exhaust. It is my opinion, I have no proof- just speculation on my part based on what I know about HP ratings and tube size.
Old May 28, 2005 | 01:05 AM
duranged's Avatar
Car: '88 firebird/'98 durango
Engine: 2.8v6/5.2v8
red, i love you, will you marry me?? PLEASE?? i will treat you good, and i got 2 firebirds? we can let our cars mate and grow our own little firebird farm??
Old May 29, 2005 | 07:52 PM
redraif's Avatar
What range RPM would you need me to try and get...going to go back soon! Testing the new chips...see if I can get a chart showing low rpms as well! Hopefully my old pulls on file will have the lower RPM for the 2.25 & 2.5 exhaust pulls!
Old May 29, 2005 | 07:53 PM
redraif's Avatar
Well thats my first on line proposal!
Old May 29, 2005 | 10:46 PM
duranged's Avatar
Engine: 2.8v6/5.2v8
hey hun, a hot girl with a nice v6 bird, your the girl of my dreams, come to connecticut, we'll get a house with a 5 car garage, let our birds mate and live happily ever after in our own little bird sanctuary,lol
Old May 31, 2005 | 08:47 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
(laughs)
Congrats on the mod and the gains! How did the 3" fit over the rear axle? Did they at least crimp the pipe so the suspension doesn't crunch it? Was it an aftermarket cat-back or a custom-bent one?
Old May 31, 2005 | 09:28 AM
LT1guy's Avatar
Car: 1987 Trans Am
Leghumpers!
Tom, it started out as a Flowmaster cat-back, but it was modified a little at the front (the cat is now flanged on both ends, so it can be removed and replaced with a "test pipe", and there is a 3" cutout) and at the back (to accomodate 4 tips, which didn't turn out like she wanted so its being re-done, as soon as the tubular a-arm issue is resolved). All the mods were done with mandrel bends. The y-pipe was custom built from 2 1/2 mandrel bends.
Old May 31, 2005 | 12:36 PM
redraif's Avatar
Tom...I plan to get some pics when I get the tips redone! I will document what he did and post it up for you guys!
Old May 31, 2005 | 02:25 PM
redraif's Avatar
Though now that I think about it the car is not going to really be able to show anything till the stall point of the convertor anyway, right?!
Old May 31, 2005 | 02:53 PM
Car: 91 Camaro
yup....pretty much.
Old May 31, 2005 | 03:14 PM
redraif's Avatar
Figured...oh well the point was to have a system that was matched to my car, with my mods...that it is!
Sucks I could not get a dyno run in with the new chip...they were closed on Sunday when we got there. Then on the way back my A-arm broke...tubular unit... car and I both fine. Broke just before i entered the expressway...in turn lane before ramp. One leg of the A snapped... passenger side... rear leg! Car is still drivable to manuver only... would not trust it for anything but a crawl!
So no new dyno results yet with the new chip!
Old May 31, 2005 | 03:24 PM
Car: 91 Camaro
a. you're running tubular a-arms?? nice, i want some, too!
b. how did it break? did you (or have you) hit a pot hole or something?
Old May 31, 2005 | 04:02 PM
redraif's Avatar
Check this out...
no pot holes or anything. Just driving along straight and actually only at about 15mph in turn lane! Or if it happened in the gas station...2-5mph!
Old May 31, 2005 | 04:26 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
redraif this is a purely honest question, what did that do to the torque curve and did you keep the stock manifolds, or headers that would fit that 3.8?
Old Jun 1, 2005 | 01:35 AM
87blueracr's Avatar
Car: 1987 camaro & 70 mustang
Engine: 2.8l & built 351C
Transmission: borg warner T-5
i have been thinking about making tubular truck arms for mine, but haven't gotten ahold of some square tubing to play, but it really doesn't look that hard to do. perhaps you could post some pics.
Old Jun 1, 2005 | 03:16 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Redraif, I am trying to understand the details of your exhaust before and after.
Wahat I am curiuos to know is-
1a)What Y-pipe did you use for the first dyno run using the PF&E headers and the cutout? Was it one from Greg, or was it something you had made? 1b) Where exactly was the cutout (pics?) and did the y-pipe flow into the 2 1/4" system at all then to the 2 1/2" cutout?
2) Sound like if I am understanding correctly that you made a completely new Y-pipe coming of the PF&E headers into 2.5" y-pipe primaries, then y-merging into a single 3" flange? The PF&E Y-pipe has 2" primaries and then Y-merging into a 2 1/2" flange. IS this info correct? Pictures if possible?
If I am understanding this info correctly, you are saying that there was restriction in the PF&E y-pipe even with the cutout and that the y-pipe needs to be larger?
Dean
Old Jun 1, 2005 | 03:43 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Here's a pic of the PF&E y-pipe in question. Was your y-pipe on the first dyno test with the cutout identical to this? and was there any 2 1/4" crimp bend pipe exhaust section in between this y-pipe and the cutout you ran?
Attached Thumbnails 3in Exhaust....We were so right!!!! :P-headers-0002.jpg
Old Jun 1, 2005 | 09:31 AM
LT1guy's Avatar
Car: 1987 Trans Am
Its a 3.4, not 3.8. The dyno tests shown are with PF & E headers, though some of the earlier tests were with stock manifolds. No improvement was seen initially from the headers and y-pipe (also PF&E), but this could be due to the fact the car was never tuned for the new engine and had a terrible crimp-bent exhaust system behind it. The torque has always been good (well, since it has been a 3.4), but it is FAR better than before as shown by the graph.
Old Jun 1, 2005 | 09:44 AM
LT1guy's Avatar
Car: 1987 Trans Am
Dean
I'm sure Redraif will pipe in at some point, but I'll try to answer your questions.
1) the y-pipe used in the first dyno test was made by Greg, and was the original prototype used on his personal car. The cutout was behind the y-pipe, and frankly all the exhaust work done by the muffler shop to connect it all together was a complete abortion. Notice the bend behind the y-pipe, which severely restricted flow.
2) Yes, a new y-pipe was built out of 2.5 inch mandrel bends, and goes to a 3 inch collector. The PF&E y-pipe had 2 inch primaries going into a 2.5, but 2.5 collectors. Not sure if there are any pics of that yet, I'll check.
I know part of the restriction was the bend just past the y-pipe, but based on the torque readings I would say that a similarly modded 3.4 needs a 2.5 inch y-pipe. The cutout could not fully overcome the restriction inherent in the whole system; now, the new cutout gives near identical results when open.
Attached Thumbnails 3in Exhaust....We were so right!!!! :P-667580_61.jpg
Old Jun 1, 2005 | 09:45 AM
LT1guy's Avatar
Car: 1987 Trans Am
The old system. As you can see those two bends were a major restriction.
Attached Thumbnails 3in Exhaust....We were so right!!!! :P-667580_65.jpg
Old Jun 1, 2005 | 11:30 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Well I'll be damned. Now I understand why the 3" catback was beneficial.
I first thought you simply plugged a 3" catback setup onto the exit of the PF&E 2.5" y-pipe exit and where claiming better #'s than a 2.5" catback on that same setup. I now see that you completely built a new y-pipe off the header primaries that do NOT funnel down to 2.5"at the exit of the y-pipe.
Now I truely see where the 7hp and 14# torque came from in the larger y-pipe with cutout (regardless of yet getting to the catback system) Very impressive work and laying down money in experimenting. It could have been a costly mistake and you gambled and won- to the benefit of myself also. Thank you very much for the info, time for me to re-evaluate my y-pipe choice and overall catback setup when I install the 3.5. I am expecting it to yeild about 250hp+ and some major rpms. Just like everything else I have done to this car already, I think we I know I mean business (just have to get some other projects out of the way first and then finish this damn motor build)
The PF&E setup is going to go onto the car then ASAP with the 2"y-pipe onto the current 2.8 motor with the existing 2.5" cat and mild steel 2.5"catback with the rear Flowmaster. I will put the rest of the custom SS exhaust on hold until the 3.5 install and will worry about rebuilding the entire exhaust with an I-pipe muffler then. Good thing, I was just about to order mt 2.5" SS mandrel bends, tubing, v-clamps, cat, and muffler to rebuild my entire system custom getting ready for the 3.5. I will now just order some steel mandrels just to connect the PF&E setup to the current steel 2.5"exhaust for now.
Old Jun 1, 2005 | 12:54 PM
redraif's Avatar
The above dyno chart is the best way to compare what it did to my curve...basically the curves trend was the same...the difference in the numbers increased a bit more the higher the rpms...as did the hp... So basically to summarize the Car gained even more TQ and HP the higher the RPM then before. Though the peak reading were in about the same place RPM wise!
The stock "3.4" manifolds are still at my house.
Old Jun 1, 2005 | 01:03 PM
redraif's Avatar
The link I posted above are the pics I have of the a-arms...check it out...see if those pics help. If not we are removing them tonight/tomorrow night and will be taking plenty of pics!
Old Jun 6, 2005 | 10:04 AM
LT1guy's Avatar
Car: 1987 Trans Am
Yes, it was a pretty big risk...all those mandrel bends plus a catback, new cutout, and lots of fab time at the muffler shop...lots of $$$, with the risk that it might not have worked. Needless to say I am very pleased with the results. Sometimes you just have to go with an idea and see what happens.
Terrell351
Jun 13, 2021 01:13 PM
MidnightZ
Dec 2, 2001 11:58 PM
FAST85Z28
Nov 15, 2001 09:47 AM
1982chevycamaroz28
Sep 19, 2001 03:24 AM
RoadRocket L98
Apr 25, 2001 06:22 PM
