Whats the diff in a V-6 T5 and a V-8 T5
Old May 24, 2003 | 04:41 PM
ChellysCamaros's Avatar
Please help me.. I am not very knowledgeable about these transmissions and I am in major need of one for my V8...So far finding one of these have been like pulling teeth out of a shark while hes swimming... sigh.. any help would be appreciated and please hold your snickers fellas....
Chelly
Old May 24, 2003 | 06:29 PM
1986redbird's Avatar
welcome aboard, the only difference between the two is the bellhousing. they are different between the V-6 and V-8, it may be easier to find a T-5 setup and then buy the needed bellhousing seperatly.
Old May 24, 2003 | 06:55 PM
Thanks for the welcome.... I have a T5 bellhousing for the V-8.... but I am guilty of not keeping it full of fluid and the insides are toast... I need just the tranny part... I am having such a hard time finding one for a V8 and have noticed more posts for V6 T5's... so I guess what Im asking is... Can i buy one of those and it fit right in and run? or is there going to be some gear changing and the like going on?
Thanks for not laughing
Chelly
Old May 24, 2003 | 08:05 PM
you can get a T-5 for a V-6 and swap your V-8 bellhousing onto it, theres only like 4 bolts that hold the gear case to the bellhousing.
Old May 24, 2003 | 08:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's a bunch of junkyards in Memphis that should be able to get you one.... Check Payne's on North Hollywood, Mr. Complete on Chelsea, the one on the north side of Chelsea between McLean and Watkins ( I can't remember the name of it, I haven't lived there for too long now).
Old Jul 10, 2003 | 02:18 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
So their is no difference in the v-6 or v-8 t5 besides the bellhousing? I thought there was a difference with the input shaft? Anyone got an answer to this? I'm shopping for a t5 setup right now and need this info.
Old Jul 10, 2003 | 05:20 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I believe you need to use a V6 clutch and pressure plate.
My friend is running that setup in his 86 Trans Am right now since it is so hard to find a V8 T5.
Old Jul 10, 2003 | 06:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The input shaft is different. The 6-cyl one is 14-spline and some small diameter, the V8 is 26-spline 1-1/8" diameter. I don't know too much about the 6-cyl cars as far as details since I am entirely disinterested in them. I've never even touched one of those transmissions except by mistake once when a junkyard gave me one instead of a V8 core, and once helping one of my little brothers with his S truck.
Old Jul 10, 2003 | 08:21 PM
88 350 tpi formula's Avatar
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I has lower gear ratios. and like sated above the splines are differant. you could get just the disc from a parts dept. but, you may need to go through a bunch till you find one with the right splines and the right diameter disc. someone thought a 82 f-body one "might work"
Old Jul 12, 2003 | 08:31 PM
LetsRock's Avatar
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
The splines are different as well as the gear ratios. One I got from a junkyard had a huge counterweight thingy on the tailshaft. Be patient and keep searching till you find one for a V8
cammy
Sep 22, 2003 10:21 PM
KED85
Apr 8, 2003 08:55 AM
wicamaro84
Nov 23, 2002 10:56 AM
motorman
Nov 20, 2002 01:47 PM
pokes87iroc
Jan 17, 2002 08:19 AM
