Alternator recommendations
I think it's time to replace my alternator and I was just wondering what you guys recommend. I have put in power windows, locks, and some other accessories since I bought the car. I also plan on putting in dual electric fans, so I was wanting to upgrade from the stock output. What brands are good and what power rating should I look for? Thanks alot.
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I would like to have one of those also, How do we go about finding one when we go to the parts store. I have no idea how to specify B4C Alt.
Brian
Brian
How many amps are good for a Camaro with underdrive pullys and a 1 amp stereo. I also run a MSD. I get plenty when the car is off idle but I could use a little more.
Brian
Brian
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
called my local chevy dealer and they new absolutly nothing about the b4c option package.. and had no clue.. gonna try and calling gmparts direct either later today or tommarrow and see if they have a clue.. will keep you all posted..
For your info the B4C option Alternator was for the Police package. If you still want a 140 amp one just ask for the highest output A/C Delco one they have and forget about B4C code.
Car: 91 RS
i emailed gmpartdirect this afternoon .. by the way that car is on ebay.. thats how i got the vin #. ill post the reply
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1847451565
"hi i am looking to get a B4C replacment alternator rated @ 140amps.. my local gm dealer new nothing of the b4c option package.. here is a vin number of one of these such cars 1G1FP2389NL148973. If you can get these please let me know the price so i can notify several intrested people on Thirdgen.org. We might be buying some.
thanks"
thanks"
thanks"
thanks"
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
If you go the B4C alt route, don't forget to buy the B4C alt bracket (p/n 10118722) from GM.
Car: 91 RS
The following was taken from the post at the forum you sent us a link to.
10118722) from GM.
10118722 doesn't exist in our database. I was hoping this part number would lead
me to the alternator in question but to no success. We did however find out that
the B4C option is a police package vehicle. 90-92 only shows two alternators in
the catalog. One is 100amp the other is 105amp. The VIN you sent does show that
the car came with the B4C option. GM shows that the alternator for this vehicle
is the
10463172 alternator 105 amp
We have no knowledge of a 140 amp alternator. Good luck!
10118722) from GM.
is the
10118722) from GM.
is the
10118722) from GM.
is the
As I said in the previous Post the B4C was the Rpo code for the Police package and not for a type of Alternator. The highest AMP
A/C Delco is 105 max. And the brackets fits both Delco Alternators. Let this be a lesson, don't go after something without good info.:lala: :lala: :lala:
Here's the part numbers for the B4C alt upgrade (this is for serpentine belt systems):
B4C Police Package 140 amp alternator GM p/n 10463338 (ask for a Police Caprice alt at autopart stores)
B4C alt adaptor bracket GM p/n 10118722
Car: 1987 Iroc Z "Classic Roc"
Engine: 5.7 350
I bought an Iceberg 140amp. Put in in about a month ago and haven't had any problems.
http://www.alternatorparts.com/iceberg.htm
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
From my research, the Caprice alternator for police/taxi applications is a 124-amp model. They cost about $150 plus core.
Car: Check The Sig
i got rebuilt 105 amp one from AC... it was $105... not bad... my underdrive pullies killed my old alt... but i found out that the alt that was in there only put out 85amps...wtf? and I am(well my dad) is the original owner... and he never knew it was switched out.... i suggest 140amp... thats what im gettin with a new motor...powermaster or a rebuilt cop alt are good alts... and i have seen rebuilt alts last longer then O.E's...
raymondandretti
09-27-2015 06:43 PM
