Well, I am cutting the hole
Old Jun 17, 2003 | 04:44 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
my fuel pump is shot, and i am going to have to cut the hole and make this job as quick as possible. i dont have the time or the resources to drop the tank. i am wondering if anyone has any pics of this process. thanks in advance!!!no flames please!!
Old Jun 17, 2003 | 06:20 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Can't help ya with where to cut the hole, but am curious if you actually do save time?
I'm thinking...
Remove backseat, carpet, cut a hole, then reinstall and seal the "plate" you cut out, then the carpet and seat again. Maybe you just need to lay the seat forward? I dunno.
I guess if you don't have jackstands and handtools I could see your point.
Good luck...get ready for the thread
Old Jun 17, 2003 | 08:42 PM
fakezcar's Avatar
I can try to get you some pics of my hole. I recently cut one for mine since I blew out the little rubber hose connecting the sending unit to the pump. my recomendaion is get a set of good (read high) jackstands and do it right. You'll have to remove the exhaust, and the heat sheids. You can get away with dropping the axle but leave the front bolt on the control arms in. you'll also need to disconnect the panhard rod from the frame. The additional brace by the panhard rod needs to come out also. Use some heat on the single bolt and it should come oout no problem. Un bolt all the little stuff around the filler neck as you'll need to move that around. You'll also want to pull out the inner fender on the drivers rear also. Then it's just a matter or twisting the gas tank until it falls out. It's a lot easier than it sounds. If you do cut the hole you still need to unbolt the tank and pray it sits low enough to get the sending unit out easily. I ended up ****ing up my sending unit and now I don't have a gas gauge, so it's smarter to do it the long way. If you have a little knowledge of the rearend and how everything sits you should be ok. Let us know how it goes though.
Chris
Old Jun 17, 2003 | 08:44 PM
bubbz89's Avatar
Car: 1990 RS
i know how to do it right. been there done that. im cutting the hole due to the circumstances
Old Jun 17, 2003 | 08:50 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I started to do that, as I drilled several holes I noticed how close the fuel lines are to the sheet metal. It looked like the tank must be dropped, even if it rests on the panhard rod brace, maybe 1" or 2" to have clearance for the saw. It turned out not to be the fuel pump. good luck
Old Jun 17, 2003 | 08:51 PM
BOTTLEDZ28's Avatar
Transmission: A4
DONT cut a hole. it not safe and will take just as long. It will never be right when its done. if you say you dont have the tim eor resources to do it right then how do yo uhave them to do the hole? You need a drill, cutoff wheel, compressor, hand tools and a welder. if you have those then you must have a jackstands and a bunch of sockets and a rachet. Its not hard at all to drop the tank........the last thing you want to do is be cutting near the fuel lines
Old Jun 17, 2003 | 08:56 PM
bubbz89's Avatar
Car: 1990 RS
i appreciate your concern man, but i am cutting the hole.
Old Jun 17, 2003 | 09:06 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
https://www.thirdgen.org/techbb2/sho...hole+fuel+tank
Use these key words and do a search ..tons of info on this one!
Old Jun 17, 2003 | 09:22 PM
bubbz89's Avatar
Car: 1990 RS
thanks a million!!!:hail:
Old Jun 17, 2003 | 09:38 PM
Engine: 406
Your welcome..
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:40 AM
355tpipickup
Sep 13, 2015 11:35 PM
Glowsock
Sep 5, 2015 07:48 PM
