my speed do. setting is messed up please HELP!!!
Old Nov 15, 2004 | 10:53 AM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
ok i need help i just installed these gauges from pro car parts http://www.procarparts.com/store-det...=onlinestoreDB
and i had to take off my needles and now my speed do. is really off i am going really fast my the time i hit 20 mph on my speed do. what can i do and what should i do to fix this?
Old Nov 16, 2004 | 05:35 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
I just installed the same guages from procarparts this weekend, well almost the same ones. Mine don't have the donut around the center of the needles. I took many digital pictures before in order to see where things were supposed to be at start up, warm idle and at speed.
They seem to be accurate, but I don't trust em though, then again I didn't before I pulled the needles.
When placing the speedo needle back on it should be positioned exactly between the bottom stop peg and 5 mph. With the car started.
After 2 or 3 trys I got right where I wanted it. Be delicate.
Ideally they all will need to recalibrated.
BTW: Is your tach accurate?
Old Nov 16, 2004 | 07:40 PM
Car: 1997 S10
i think my tach is pretty accurate but i am am not sure about my fule gauge it was ai also have a question about the wire you hooked the gauges up to on the headlight switch my dad has them hooked up so there all ways on can you help me out?
Old Nov 16, 2004 | 09:14 PM
Car: 91RS_92Z28
Engine: 5.0_5.7
Where is your RED power wire hooked up to?
Are they always on, even w/ the car off?
You could put an on/off switch inline with the red wire, that is what I did. I wanted total control to turn them on and off.
Whatever you do, DO NOT use the orange wire coming off of the headlight switch, that is the dimmer wire. It will burn out the guages according to the instructions, if you can call them that.
Before my install 1500 RPM in Fifth gear = 55 MPH. EDIT: I see you have an automatic, your math will differ. I have a T5 with the 3.08 rear end.
As for the fuel guage go fill it all the way up and attach the needle at full.
Old Nov 17, 2004 | 10:32 AM
Car: 1997 S10
no there not on al the time just when i start the car till i turn it off thanks for your help
Old Nov 17, 2004 | 10:45 AM
Car: 91RS_92Z28
Engine: 5.0_5.7
No problem. This is one of the coolest mods I've done to the interior. I love the fact that you can see them from way outside of the car at nite.
BTW: Did you paint your needles?
Old Nov 18, 2004 | 10:05 AM
Car: 1997 S10
no i did. not not did you? i would need to find a nother set becouse i do not want to mod anyhting thing that i cant change back to stock. but if i can find a nother set and find out how to change the color i would like to.
Old Nov 18, 2004 | 04:04 PM
Car: 91RS_92Z28
Engine: 5.0_5.7
I colored my speedo and tach needles red and left the rest factory orange/yellow. At first I painted the backs of them with model paint and they did not glow at all. I sanded that off and used a red opaque art marker. They still are not as bright as the factory needles.
I also changed the four factory white bulbs with red Polarg brand 194 bulbs so all the needles glow red. That is a must with the indiglos, imo.
Old Nov 18, 2004 | 07:00 PM
Car: 1997 S10
i an still thinking about what color i want to go with also have you done anything with your other overlays like HVAC or you shift indacator?
Old Nov 20, 2004 | 07:10 PM
Car: 91RS_92Z28
Engine: 5.0_5.7
My HVAC is covered with carbon fiber look tape, so it has no markings anymore.
5-speeds have a diagram of the shift pattern that doesn't light up. I cut it out and mounted a RAZO indicator that lights the shift pattern in green. I don't think they make it anymore.
I'm thinking of changing the needles to green, or at least some of them.
Attached Thumbnails my speed do. setting is messed up please HELP!!!-img_0034crpd.gif
Old Nov 22, 2004 | 07:16 PM
Car: 1997 S10
cool picture how come your speedo needle is not lit up?
Old Nov 23, 2004 | 12:20 PM
Car: 91RS_92Z28
Engine: 5.0_5.7
It is, it just happens to be the dimest of the four needles.
I also tweaked the pic to tone down the blurryness.
colton_carlson
Mar 8, 2019 12:21 PM
bamaboy0323
Sep 3, 2015 06:07 AM
nuggie
Aug 25, 2015 01:27 PM
perZ
Aug 15, 2015 01:17 PM
mx127
Aug 10, 2015 08:13 AM
