Woo hoo!!! Just got my double roller chain today, im set!!!
Old Dec 28, 2004 | 03:24 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Alright, got everything for the cam swap now.
Electric Waterpump....Check
High Lift Valve Springs....Check
Cloyes Double Roller Timing Chain....Check
CC306 Bumpstick (230 / 244, .510 / .540 112 LSA)....Check
I can't wait to start tearing that corvette *** up with this cam. Anyone know a pretty good way to change valve springs? I've done it before using a air compressor however, i've never done the turn the crank thing. I've taken my balancer off a couple times. Do these go on only one way? I wouldn't want the timing arrow to be off and drop a fricken valve on to the piston.
Old Dec 28, 2004 | 05:48 PM
pasky's Avatar
All together:
Attached Thumbnails Woo hoo!!!  Just got my double roller chain today, im set!!!-all.jpg
Old Dec 28, 2004 | 05:49 PM
pasky's Avatar
Electric waterpump:
Attached Thumbnails Woo hoo!!!  Just got my double roller chain today, im set!!!-waterpump.jpg
Old Dec 28, 2004 | 05:50 PM
pasky's Avatar
Double roller! :rockon:
Attached Thumbnails Woo hoo!!!  Just got my double roller chain today, im set!!!-double-roller.jpg
Old Dec 28, 2004 | 07:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yup, thanks to the crankshafts woodruff key, the balancer can only go on in one direction.
The compressed air is the fastest and easiest way to hold the valves up during spring removal. Otherwise, yes, there is the nylon rope slid into the chamber then the crank is rotated to pin up the valves. It works, but it's time consuming (compared to compressed air) as you have to do each cylinder seperatly, or if you know the various stages, you could do both the compression and the exhaust stages for 2 cylinders at a time (i.e. cylinders #1 and #6). Up to you and what you want to do.
Old Dec 28, 2004 | 07:12 PM
pasky's Avatar
Well, this is going to be at someones shop, don't believe he has an air compressor. So looks like im gonna be doing the time consuming part. I can do 4 springs at one time right? Since when one is TDC another is at the same time correct?
Old Dec 28, 2004 | 07:24 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
You can. I like to do one at a time, completely. That ensures all my attention is on that one cylinder (those damn locks....). I just follow the firing order around and go through 2 complete rotations on the the crank.
Do you have a crank rotating tool?
Old Dec 28, 2004 | 07:29 PM
pasky's Avatar
Nope, was thinking I could just turn it with the balancer. Or does the hub need to come off to swap a cam? I've never done a cam swap.
Old Dec 28, 2004 | 07:32 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Read through my sig. It contains all you need to know.
You can rotate it by the balancer. I would rotate it by the pulley instead.
And yes, the entire assembly needs to come off - basically, you need to expose the crankshaft snout.
Old Dec 28, 2004 | 07:45 PM
camaronick91's Avatar
Car: 91 z28
Engine: 350 stealthram
u should but an impeller on that water pump to reduce cultivation
Old Dec 28, 2004 | 08:01 PM
pasky's Avatar
Huh? That IS the impeller.
Old Dec 28, 2004 | 08:02 PM
pasky's Avatar
Awesome, thanks.
Old Dec 28, 2004 | 08:44 PM
Car: 91 z28
its a thin round disk made of stainlessteel u put on over the impeller fins. this reduces air in the system
Old Dec 28, 2004 | 08:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Leave the impellers alone. If you are worried about air in the system, run a surge tank.
Old Dec 28, 2004 | 09:12 PM
pasky's Avatar
Im not worried about air, the lt1's have a bleeder screw on the thermostat housing.
Old Dec 28, 2004 | 09:25 PM
DENN_SHAH's Avatar
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
sweet
i think he is talking about cavitation, which i doubt you will have any problems with using an electric water pump unless it spins pretty fast when its in the motor & moving water.
some info about cavitation
http://www.mcnallyinstitute.com/01-html/1-3.html
http://www.engineeringtoolbox.com/34_407.html
Old Dec 28, 2004 | 09:33 PM
Car: 91 z28
it will increase water flow up to 30%. i had air forming in the coolant because my hyperformance water pump spun so fast it was creating air. took it off put the disk on and haven't had a problem since
Old Dec 28, 2004 | 10:06 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
if you have the money tho you might as well run a purge tank or surge tank that lets air our form the overflow tank. i thni summit sells em
Old Dec 29, 2004 | 10:58 AM
Damon's Avatar
A late model LT-1 engine? Make sure you have the right timing chain. LT-1s have some quirks to them that restrict which timing chain/gearsets you can use. I don't recall any double-row chain sets available for the LT-1 but I haven't worked on those engines much.
Also, I'm not sure about the clearance on a stock LT-1 head between the retainer and valve guide seal but you better be sure it's got more than your cam's max lift. Older SBC heads would regularly run out of room at only .470 lift, but I'm not sure what kinda clearance an LT-1 head has.
Old Dec 29, 2004 | 12:24 PM
pasky's Avatar
I have a 95. The 93-94's have the quirks. Also the 96-97 have the crank position sensor that has to be deleted. I got the best of the years for the lt1. 95 Had the vented opti and was still OBD I . The only way to use a double roller on a LT1 is to run an electric waterpump. Thatr way the crank no longer turns the waterpump.
Old Dec 29, 2004 | 03:38 PM
pasky's Avatar
Poo, just found out you need to mark the crankshaft hub position because the LT1 isn't keyed. Just one more thing to do I guess.
Old Dec 30, 2004 | 02:37 PM
pasky's Avatar
Mua hahaha, found a clip of the CC306 at idle:
http://camaro.ccurtis.net/media/carstart.mp3
Chug-a Chug-a Chug-a
Gonna suck in small children and kill tiny wild flowers when I drive by.
Old Dec 31, 2004 | 02:07 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Haha.... Parts look good Pasky, how much power you looking at adding?
Best of luck,
Brandon
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
