Hood Alignment (Sticky Please)
Car: 78' Corvette
Engine: 383
Hood Alignment
Before
Loosen the two bolts with a 13mm socket and lower the hood latch, When done tighten the bolts.
"Make sure the rubber bumpers are adjusted properly also you don't want too much tension when it is closed." - NoItsNotForSale
After
Car: 78' Corvette
Engine: 383
Glad i can help.
My father showed me how to do this, I know very little about cars.
Btw, send me a pic of how it came out.
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Make sure the rubber bumpers are adjusted properly also you don't want too much tension when it is closed. Looks Good!
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
how do i make sure the bumpers are adjusted properly?
Car: 78' Corvette
Engine: 383
Originally posted by 83_Camaro_83
I would so sticky this, EVERYONE complains about hood gap..... nice find
I basically just made this for lxcamaroxl, I figured since i spent the time on it, ill make a thread incase anyone else needs help.
Car: 92 Camaro (R)eally(S)tock
Transmission: Auto 700r4
I tried this and it didnt work.
Still Maddona gap
I even lowered the rubber bumpers.
if i push down on the front of the hood, it pushes down.
Still Maddona gap
it helped but its still not that good.
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
It's hard to tell you how to fix it without seeing it. You can adjust the hood forward and back also. A lot of thirdgens I see have gaps because the hood is too far back.
i think thats my problem. its pretty low now, but still too far back (in the direction of the windshield). also, the front corners are too low, but thats also probably from them being too far back. i would really like to fix this, could you let me know how? thanks a lot for the first tip.
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
The hinges where the hood bolts on and where the hinge bolts to the fender are slotted. Slightly loosen the bolts and you should be able to slide it forward some. Then adjust your bumpers and catch till it sits at the right hight.
ill get my teacher to do it (auto body) because he can probably do it in like a minute.
There is nothing wrong with the car in the first picture, of the owner of this thread.
GM didn't design the hood to lay on the front cover. There SHOULD be a small gap.
The third picture is too close and will cause the hood to rub while driving, which, in turn, will take off paint.
This is in direct contrast to SOME of the camaro's out there that actually have the problem of too big of a gap.
Which can be any number of things. Not the least of which would be a prior accident that did not get properly repaired.
No i think it still is helpful because i could make it close to touching but not touch, just so the gap is smaller.
like i said too, its better, just not perfect.
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
I could not get my gap right. I tried everything and could not get it. I was looking around and found that the metal that latch bolts to was bent(twards the lower bolt on the bottom of the car). I had a parts car, so I grabed that one and replaced it. Now it is perfect. That is one thing I would check too.
Car: 87 IROC-Z
Transmission: automatic
There are also four bolts, two on each side, near the headlights that are adjustable, they help hold the front clip to the car. I had to play around with these to help get my hood gap fixed.
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
