Fuel Injetor "O" rings
I'm about ready to assemble my injection system and need a little advise. Other than size, is there anything special about the "O" rings for the injectors and fuel rails.
Roy
Roy
They're probably made out of Viton or some other chemically resistant material, but you're best bet is to get some AC Delco ones and use them. Which ones have you purchased? Hope this helps.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
1990 IROC 350
If you want the dealer's injector o-rings, the part number is 17112222.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
1989 IROC-Z 5.7L
NOS 5151 150HP kit
Car: 86 T/A
Engine: 5.0 TPI
Most definitely use the big beefy blue GM o-rings. They go on better and are made for the purpose. When you order the fuel rail o-rings make sure your dealer is getting you ALL of them. The fuel rail o-ring kit doesn't have all the ones you need.
17111696 Fuel Rail O-Ring Kit - 19.85
22514722 O-Ring - Fuel Line in/out of rail. The ones they don't give you. Need this one and one below. This is the larger of the two. 48 cents.
22516256 O-Ring - Fuel Line in/out of rail. The ones they don't give you. Need this one and one above. This is the smaller of the two. 47 cents.
17113544 Fuel Injector O-rings - Seal Kit
$ 18.14
Keep in mind these parts are specific to my 86 T/A and the prices are from about a year ago. Yours most likely are the same.
$ 18.14
Car: 86 T/A
Engine: 5.0 TPI
PS... notice my o-ring part number is different than the other post. Make sure you check your application for exact numbers. I'm thinking this may be due to different injector sizes. Mine are 19# for a 5.0 Liter Engine.
<font face="Verdana, Arial" size="2">Originally posted by MikeInAZ:
$ 18.14
</font>
$ 18.14
</font>
Roy
Car: 86 T/A
Engine: 5.0 TPI
Unfortunately I am serious. I really thought long and hard about replacing the o-rings on my injectors because Rich at Cruzin Performance had just reconditioned my injectors and they had new o-rings.
Then I thought 20 bucks 8 o-rings. But I was still chasing a code 44 and I thought they might be leaking. There was no comparision to the standard rings vs. the GM rings. If you get them you will see what I mean.
On the fuel rail kit I didn't want to sit there and match exactly all the right sizes so I just got it. By all standards you could hand pick the fuel rail o-rings from NAPA for probably 4 bucks.
Transmission: Pro-built 700R4
Rich at Cruzin Performance had just reconditioned my injectors and they had new o-rings.</font>
Car: 1992 B4C 1LE
Yeah I found them at napa dirt cheap as well, fo regular stores the "Help" brand section offers a package of assorted orings for cheap and low and behold like 6 of the ones in the package were injector orings (I was amazed) so I bought a couple of packages.
O-rings? you mean there are supposed to be O-rings around my injectors??
Uh oh...
Uh oh...
1989 IROC-Z 5.7L
NOS 5151 150HP kit
1989 IROC-Z 5.7L
NOS 5151 150HP kit
Car: 1992 B4C 1LE
I dont replace mine unless they are deformed, flat or torn.
hectre13
12-11-2023 08:14 AM
ambainb
04-25-2016 09:21 PM
lt1z350
09-29-2015 01:50 PM
