9 bolt.com
Car: 1992 RS, 1989 GTA
Engine: 5.0 TBI, 5.7 TPI
Transmission: T5, 700R4
Axle/Gears: 10 bolt 3:42, 9 bolt 3:23
9 bolt.com
Has anyone dealt with 9bolt before. The website is very plan and no phone number, too me is usual. Yes they are from down under mate, but I would like to talk to someone.
Re: 9 bolt.com
Don't bother. You don't need Glen's help with anything. The 9 bolt has a junk carrier. Get a Torsen from Supa-F Spares for a Holden Commodore VL, and the Motive/Yukon/Summit 3.70 gearset.
The auburn style diff in the 9 bolt is junk, should not be rebuilt, and the one I got from Glen at 9bolt.com was crap. Lasted about 6 months of terrible creaking, groaning, and gnashing. Filled my diff with silver paint. I tossed that garbage - lesson learned - and put in the Torsen. Been good ever since.
GD
GD
Re: 9 bolt.com
This Yukon is this a complete diff or a carrier I can upgrade the 9 bolt?
Re: 9 bolt.com
The Torsen from Supa-F Spares is the carrier. Motive/Yukon, etc sell the 3.70 gears - that's the only aftermarket ratio available for the 9 bolt.
The thread on my upgrade:
https://www.thirdgen.org/forums/tran...rg-warner.html
GD
GD
Re: 9 bolt.com
Thank you Sir the link to your older post is very informative. I have read the 9 bolt is a good diff, but... My bird is not original but I would like to keep as much as l can OEM. Thanks again
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: 9 bolt.com
I don't even add the limited slip additive, and I don't get any noise out of it
I am in no way thinking this is going to last me another 100,000 miles and still function as a posi, but it got me some additional life without having to spend much money to keep the two wheel drive.
Re: 9 bolt.com
I certainly did get shafted. Near $450 for a rebuilt 3 series carrier and bearings/seals that lasted a couple thousand miles. I tore it down after the fact and it was DESTROYED. Now I'll be the first to admit I'm not even close to gentle on cars, but this car had a 150k mile LB9 and a completely stock automatic at the time. The gears and my setup of them weren't the issue as they are still in use on the Torsen. I tried 3 different fluids per Glen's recommendations - before he just stopped responding to my emails - nothing helped. It creaked and groaned and popped driving around parking lots. It was honestly embarrassing how loud it was. And then it stopped working and was just open towards the end.
GD
GD
Car: 92 Firebird
Engine: 4.8 LR4
Re: 9 bolt.com
GD
GD
I plan on doing the torsen type carrier once I get some of my other projects out of the way, but I think I am going to wind up grinding my friends carrier like I did mine, unless he comes up with the cash to buy the torsen by that time comes
Re: 9 bolt.com
What are these different fluids y’all speak of? Are we talking ATF, different gear oil weights?
Car: 92 Firebird
Engine: 4.8 LR4
Re: 9 bolt.com
I just put 80w90 Amsoil gear oil in mine, don't even put in friction modifier with it as per the factory service manual unless it needs it
Re: 9 bolt.com
The Amsoil severe gear has friction modifier already in it. They do make Slip Lock if you want to add more.
With the Torsen nothing special is required. I just run Amsoil 75w90.
GD
GD
Car: 92 Firebird
Engine: 4.8 LR4
Re: 9 bolt.com
I can't find it now, but I don't think I have the sever gear? I bought 5 gallons of gear oil since I had 5 differentials to fill, and one of them was like 3.8 quarts on it's own. I could have sworn it was 80-90, but I don't see it on their site now, so maybe I got 80-140.... ?
**EDIT**
I guess it was "sever gear", but it does not necessarily have the friction modifier already in it, from the site;
"AMSOIL SEVERE GEAR® is compatible with most limited-slip differentials. For applications that require additional limited-slip friction modifier, add AMSOIL Slip Lock®."
**EDIT**
Re: 9 bolt.com
I'm an Amsoil dealer. They mean for applications that require additional beyond what's already in it..... it does have the modifier included just some diffs may want more.
But yeah if in doubt add the slip lock. Not going to hurt anything.
GD
GD
Re: 9 bolt.com
Thanks all good info. I have use amsoil before, great stuff.
foney_email
Sep 10, 2002 03:05 PM
bad camaro RS
Aftermarket Product Review
Feb 22, 2001 10:10 PM
smokin#8
Jul 24, 2000 06:58 PM
