Which Direction To Sand Wheels?
Old Jun 15, 2003 | 12:05 AM
89IRO's Avatar
Do I sand length or width direction?----
Old Jun 15, 2003 | 12:19 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
I dont know if it matters or not, but i would think sanding length wise would be better.
Kevin
Old Jun 15, 2003 | 07:59 AM
colonboy14's Avatar
Car: Trans Am
Sand WITH the grain, as if you were going around in a big circle on the wheel. If you don't, you'll get all kinds of nasty scratches.
Old Jun 15, 2003 | 12:02 PM
89IRO's Avatar
So if I sand with the grain, that would be sanding width-wise correct? And do I buff in the same direction when buffing? Thanks. -89IRO
Old Jun 15, 2003 | 04:04 PM
89IRO's Avatar
Anyone?
Old Jun 15, 2003 | 04:10 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I did mine from the center to the outside of the rim, lengthwise and they look fine. You wont leave any scratches as long as you do the proper buffing after the wetsanding. Doing the tripoli and the white rouge will clear out any scratches, thats what its for.
Old Jun 15, 2003 | 04:27 PM
89IRO's Avatar
O.K., do I sand with the 220 dry to get the machining marks out? And that's what they refer to the "grain" as right? So if I were to sand with the grain, that would be sanding width-wise correct? And yes, I know about the tripoli and whit rouge, I've already got it. See the thing is, yesterday I did my first wheel, but it didn't come back in a mirror finish, so I guess that means I need to sand more. Oh, and are the buffing wheels supposed to turn black? Thanks. -89IRO
Old Jun 15, 2003 | 06:32 PM
colonboy14's Avatar
Car: Trans Am
Yes, "with the grain" is width wise. And yes, your buffing wheel will turn black, that is oxidation coming off.
Old Jun 15, 2003 | 07:53 PM
89IRO's Avatar
Great, thanks for the help guys, I guess it's time to do that wheel over, because it is far from mirror. I hear all the shine is in the sanding. At least the clear coat is already gone, because in my opinion, that is the hardest part, because I have to be soooo careful not to get any on the painted part of the rim. Later. -89IRO
1992rs/ss
Jan 31, 2025 05:10 PM
Scamo-2.8
May 20, 2016 07:01 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
firebirdta84
Interior Parts Wanted
Aug 30, 2015 09:28 PM
