Third Gen Headlight Conversion
Old Jan 19, 2004 | 04:18 PM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
If anyone is interested in third gen, headlight conversions let me know.
The conversion consists of a new molded housing that has the proper seat for a composite bulb, wether it be a 9004 or an H4.
Improves visibility 100% but that is just my opinion. Happy I bought them.
Old Jan 19, 2004 | 05:51 PM
1991 Z-28's Avatar
Car: 1991 z-28
Engine: zz4 350
Transmission: t-56
pictures?
Old Jan 19, 2004 | 06:03 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
A; I do belive this is spam.
B; Don't you mean 9003, not 9004. H4 and 9003 is the same bulb, however the 9004 and 9003 are both dual filament bulbs, but the seat is entirely unique.
C; What on earth does this look like?
Old Jan 19, 2004 | 06:16 PM
FLYNLOW92rs's Avatar
:lala: :lala: :lala:
My first grade teacher told me i have a wild immagination, but i still have no idea what you are talking about??????
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
:werd:
Old Jan 19, 2004 | 08:50 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Originally posted by 1991 Z-28
pictures?
:werd:
Old Jan 19, 2004 | 08:52 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
@AlabamaThunder
@jensen73110
:werd:
Old Jan 19, 2004 | 11:30 PM
CrazyHawaiian's Avatar
Car: too many ...
:hail:
Old Jan 19, 2004 | 11:33 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Old Jan 21, 2004 | 12:52 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i know what that person is talking about.....it is a conversion kit to turn sealed beams into composite.....i did it to my trans am....sorry no pics but i must agree it did improve my visability by a lot....i had the cool blue sealed beams and did the conversion and added the cool blue composite bulbs and the results were great......i got mine at autozone....i think its like 30-40 bucks....i also believe they may have them for camaro's too....i forget.....
Old Jan 21, 2004 | 05:38 PM
KBeez's Avatar
Car: 88 Camaro S/C
Transmission: 700-R4
so does this mean I could run those Xenon "crystals" bulbs?
Old Jan 21, 2004 | 05:45 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah basically....just as long as they are in the H4/9003 format.....
Old Jan 28, 2004 | 08:33 PM
Rocket-Doc's Avatar
Bulbs
actually it's 9005 and 9006 bulbs for camaros anyway
Old Jan 28, 2004 | 08:51 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
nobody is gonna believe a newb with this....
Old Jan 28, 2004 | 08:55 PM
Car: too many ...
Yeah its H4/9003, not 9005/9006.
Old Jan 28, 2004 | 09:11 PM
Rocket-Doc's Avatar
Newbie huh........maybee to this site but not to cars.
The camaro has a twin beam set up right?
Two different intensities right?
Two different bulbs!!!
9006 low beam
9005 high beam
H4 is primarily a low beam, not a high.
Remember it's not just the way the housing reflects the light but the bulb that is generating the light that makes it a high beam.
And seeing that I have a set in front of me, and I'm looking at them, I'dhave to say your wrong.
Old Jan 28, 2004 | 09:33 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
any pics???
Old Jan 28, 2004 | 10:44 PM
Car: too many ...
Yeah I know there are two different types of bulbs. 9005 and 9006 bulbs will not just plug into your lighting system. It is possible to install them, but its not plug and play by any means. Check this thread here for more info on a 9005/9006 swap. The kits these guys are probably talking about are the direct swaps that will work with our plugs and harness. Low beams (H4656) would get the H4/9003 upgrade, and high beams (H4651) Would get the H1 upgrade. If going that route you would also want to make these changes to the wiring to avoid possible damage to the electrical system. Or could could always stick with the sealed beams and get the respective H4656/H4651 upgrades. In any event, if you are serious about lighting, I recommend you follow the tech article here.
Old Jan 28, 2004 | 11:23 PM
Rocket-Doc's Avatar
Well I am partially wrong 'cause I was speaking on behalf of my 1994 Camaro. A third gen would get H1 and H4 bulbs. As fas as the wiring diagrams I agree with the larger fuse but the stock wire should suffice....but that is my opinion. And I'll post pics as soon as I can.
Old Jan 28, 2004 | 11:45 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally posted by Rocket-Doc
the stock wire should suffice....]
The stock wiring sucks just for the stock lamps. Adding a relay kit to stock headlamps improves their lighting ability a noticable amount. But, that's just my opinion..
Old Jan 29, 2004 | 05:38 PM
Car: 1991 Firebird
"This thread is worthless without pics!"
Waiting on Dominion heads, eh? I think you'll be waiting a while....
Old Jan 29, 2004 | 09:17 PM
Might as well post pictures of my 9005/9006 conversion
They only improved visibility by 99.9999%......
Old Jan 29, 2004 | 09:25 PM
Aqua FBody's Avatar
Car: 95 Contour GL 03 KIA Spectra
Engine: 2.0 Zetec 1.8
Transmission: MTX-75 5spd
Those headlights I couldn't tell are they one peice or two.
Old Jan 29, 2004 | 09:29 PM
Aqua FBody's Avatar
Hey you guys may know. I was thinking about going from a 12V to a 16V what adverse effects will this have on my electrical system.
Old Jan 29, 2004 | 09:33 PM
1 piece....
Old Jan 29, 2004 | 09:50 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
EXACTLY the two thoughts I had....
I need a pic of it on a firebird/TA
Old Jan 29, 2004 | 10:43 PM
Rocket-Doc's Avatar
This is the kit for a fourth Gen Camaro. Third Gen are a little bigger and have H1 & H4 sockets.
Old Jan 29, 2004 | 11:56 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Flynlow.....what headlights are those for?
Old Jan 30, 2004 | 12:11 AM
deadbird's Avatar
Engine: TPI 305/ v6
Right building, wrong floor... 4thgen Camaro lights are nothing close to fitting in a camaro or 'bird w/o extensive mods (believe me, I know firsthand). This thread is just plain worthless, pics or not.
To get 4thgen camaro lights to fit a 'bird... you better dig out your creative genes. Here's the size difference in a 4thgen (or elder grand prix) lamp compared to a 3rdgen 'bird...
Old Jan 30, 2004 | 12:22 AM
Car: too many ...
:hail:
Old Jan 30, 2004 | 12:41 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Originally posted by CrazyHawaiian
:hail:
:werd:
Old Jan 30, 2004 | 12:57 AM
86WS6_T/A's Avatar
Car: 2003 Mach 1
Check his profile...
302 ci. LT1? Who destrokes an LT1?
RS/SS????
WTF is a dominion head?
Old Jan 30, 2004 | 01:24 AM
deadbird's Avatar
Engine: TPI 305/ v6
GM apparently...
Old Jan 30, 2004 | 05:20 AM
TorchTA's Avatar
In the top right pic....if you removed all that plastic and whatnot, wonder if the top would close fully and just leave the camaro light sitting there?
I've got pics on the PC of someone who did (I think) the same thing.
Just have to find em.
Old Jan 30, 2004 | 06:51 AM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
Transmission: 5-speed Rear:3.73
well with a few more "Budweiser's" you could have made them fit or at least I get more creative after a few
Old Jan 30, 2004 | 07:02 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
Its a $4000-5000 cylinder head, 4 valves/cylinder....
They flow like 355 cfm intake and 272 exhaust
Old Jan 30, 2004 | 07:33 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
is that an overhead cam head? what the heck kinda cam do you run for that?
Old Jan 30, 2004 | 07:54 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
http://www.araoengineering.com/Chevy/chevysmb.htm
Old Jan 30, 2004 | 12:40 PM
Rocket-Doc's Avatar
Does anyone pay attention??
Above the pictures i stated that they are for the fourth gen camaros.....
I'm sorry that I dont have pictures of all the different bulbs at this time.....I will post the others as soon as I can.
I've said it before the bulbs look exactly the same when installed, I only posted the pics to show how the bulb is held into the casing.
AND I DESTROKED MY LT1?? Is that "A PROBLEM"?
in 1968 Duntov got 500hp out of a 302 with the cross ram intake, it was one of the fastest cars ever made for the trans an circuit.
Plus a 302 Camaro in 69 was only a couple tenths of a second slower than the big block version.
So don't knock it.
Old Jan 30, 2004 | 03:38 PM
Car: 92 Z28
:nono: still confused about why you would spend your money destroking it?
Old Jan 30, 2004 | 04:18 PM
mw66nova's Avatar
Engine: 7.0L
alot of road race guys like those short stroke/high rev motors. i would think if he is running the dominion heads (after reading what they do) he is planning to spin the bastard to a very high rpm.
Old Jan 31, 2004 | 10:27 AM
  #42
Metal383's Avatar
Car: 84 T/A 70 Chevelle SS 78 T/A
Engine: chevy 383 Chevy 496 Pontiac 462
Transmission: built THM700r4 Richmond 6 built TH400
Like what mw66nova said, it allows higher revving and since hes waiting for dominions I'm assuming we have a roadracer with us. COOL! Any pics of the car Rocket? I'm very interested in this motor and any info your willing to provide on it.
Old Jan 31, 2004 | 07:19 PM
  #43
joshp14's Avatar
Keep it on topic.
1992CamaroGirl
Dec 25, 2017 08:45 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
