Aero wing removal
Old Feb 22, 2005 | 02:22 PM
fixin87formula's Avatar
Car: 1987 Formula T-top
Transmission: 5-speed
Aero wing removal
How do I remove the clips from the hatch window without damaging the wing on an 87 formy? My wing needs sanded and painted and I don't have the cash for an aftermarket piece. So I'm going to try to fix it.
Old Feb 22, 2005 | 03:52 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
It helps if u have 2 people since the wing is big and awkward. First unbolt the wing on both sides from the underside of the trunk there will be round rubber covers over the two bolts. Then just push the wing towards the front of the car and it will slide off.
Old Apr 5, 2005 | 11:55 AM
90_formula_305's Avatar
What other wings will line up with the aero wing holes? I have been searching for awhile and have not found any information on other wings that will line up. Has anyone swaped an IROC wing in place of an Aero wing?
Old Apr 5, 2005 | 02:11 PM
colonboy14's Avatar
Car: Trans Am
There are actually 4 bolts holding it on - two near the edge and two holding the 3rd brake light to the car (which is also bolted to the wing).
Be really careful pushing it forward if it's still in good condition, because it's really easy to crack the paint by compressing the foam too much.
Old Apr 5, 2005 | 02:36 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
The third brake light is bolted to the hatch not the wing. The only other wing that might come close to working would be the later thirdgen wrap around wing in the 90's.
Old Apr 5, 2005 | 02:41 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Heres a picture with my aero wing off. The 3rd brake light is still bolted to the hatch.
Old Apr 5, 2005 | 03:40 PM
colonboy14's Avatar
Car: Trans Am
I just took mine off about a month ago and it was definately bolted to the hatch and the wing. Maybe it's the year? I have a 90.
Old Apr 5, 2005 | 04:00 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
doesnt 90 have the newer style wing
Old Apr 5, 2005 | 04:06 PM
colonboy14's Avatar
Car: Trans Am
I dont really know what the "old style" looks like. Maybe?
Old Apr 5, 2005 | 04:16 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yes, it does!
Old Apr 5, 2005 | 04:32 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
The newer style is totally flat all the way across mine has a lip. Heres a pic of aero wing
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Thanks for clearing that up vern
Old Apr 5, 2005 | 05:59 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
hmm, so the CHMSL stays on the declid huh? is it proteced from the weather at all and how tall exactly is it, the reason im asking is because my wing has a small crack starting on the inside edge so I was debating on replacing it with a highrise but I need the highmount to pass inspection. Im just wondering how hard it would be to let that light on there and put the highrise on over top of it to mantain a factory look. Ohh and F355 do you have any closer pics of the rear deck without the wing on it so I can see the holes and stuff so I can get more of an idea of what I want to do as far as my wing goes.
Old Apr 5, 2005 | 06:26 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Are u talking about the Z28 hi rise. If so there are a few people on the board with that wing and the third brake light. Maybe someone will chime in with a pic. When i had my wing off i didnt take any up close pics. I took my wing off to see how i would like the hi rise and it just didnt look right so i went back with the aero.
Old Apr 5, 2005 | 06:30 PM
meridius's Avatar
yeah I like both wings alot but dont have the cash right now to buy a replacement aerowing so I thought I would go with the Z28 highrise since Ive seen pics of it before on birds and I like it and its alot less expensive than mine.
Old Apr 5, 2005 | 06:45 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
The only problem is u have to have make the wing wider to fit a bird. Camaro's are a couple of inches narrower. When i put the wing on my car and got it prefectly centered the bottom of both ends of the wing sit dead center on top of the crack between the hatch and the fender. So u have pretty much the thickness of the rear quater skins with no wing on both sides. The camaro it goes all the way across. You could make a costly mistake thinking it will even come close to working out of the box. The aero wings mounting holes are a about 5 inches off from lining up. You can make it fit and look perfect if u know how use fiberglass.
Old Apr 5, 2005 | 06:49 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
If cost is a problem buy one of the regular firebird and trans am wings drill some new holes fill in the old ones and the wing will match the car. I see people sale the standard wing for 10-20 bucks they are cheap.
Old Apr 5, 2005 | 06:52 PM
meridius's Avatar
ehh well have to see how things work out, it just pisses me off the wing is cracking already and the guy told me he just put it on a couple months before I bought the car of which I havent even had a year yet.
Old Apr 5, 2005 | 08:48 PM
Tonyrodz's Avatar
Transmission: auto
meridius I have an 89 aero spoiler on my T/A--good shape no splits, but paint cracked on it--just bought a 92 aero spoiler so I might be selling it. Interested? I'm in Pa too so you can come get it.
If so pm me.
Old Apr 6, 2005 | 05:33 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
91 was the first year for the newer style spoiler. Im actually thinking of getting that one instead of the other style cause i can get it made out of fiberglass so it wont crack like every 87-90 style one does.
Old Apr 6, 2005 | 07:47 PM
colonboy14's Avatar
Car: Trans Am
I knew I wasn't crazy. I have a fiberglass 85-90 style. You can buy them from the sponsoring vendors at the top of the page.
Old Apr 7, 2005 | 07:33 AM
TorchRay's Avatar
Car: 89 WS6 Formula
oh no kiddin? Kool....didnt know you could get the 87-90 style in fiberglass....ill def do that then. Kinda wanted to keep the car original.
Old Apr 8, 2005 | 10:54 AM
devianb's Avatar
Anyone of you guys with an aero wing have any pictures of these clips holding the wing on?
Old Apr 10, 2005 | 02:06 PM
Tonyrodz's Avatar
Transmission: auto
Also looking for pics of the clips on the hatch--but does anyone have a pic from the 91-92 aero?
Old Apr 10, 2005 | 08:58 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here is my old 86 Trans Am with the 91-92 wing on it.
I didn't need any clips on it since the arms that wrap around the glass are pretty strong, I just put some weather stripping between the spoiler on the glass so it wouldn't rattle on it.
Was stable up to 160mph on my 86.
Old Apr 10, 2005 | 09:01 PM
Tonyrodz's Avatar
Transmission: auto
Zepher--did you use your old hatch? Also--did you have to drill new holes for the spoiler or did it bolt up using your old aero wing bolt holes? I wanna put my 92 aero on my 89 aero hatch.
Old Apr 10, 2005 | 09:15 PM
Zepher's Avatar
I used the same decklid which had the stock pedestal spoiler.
I had to drill one hole on each side and used one hole on each side from the stock spoiler holes.
Old Apr 10, 2005 | 09:40 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You don't have to make it wider. It'll just be narrower than the *** end of the bird. Look at KarpsTA. His is like that.
And the 3rd brakelight is bolted to the spoiler as well. Otherwise I wouldn't have two thread bolt holes in my old stock wing from my 87.
Old Apr 10, 2005 | 10:15 PM
Tonyrodz's Avatar
Transmission: auto
thx Zepher.
Old Apr 11, 2005 | 01:38 AM
Zepher's Avatar
I had that wing and it looked great from all angles, except from the rear,
Old Apr 11, 2005 | 01:43 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Originally posted by Zepher
That's why I never got that wing. I hated how it looked from that back. True it does look good from every other angle though.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Stroopwafel
Sep 11, 2015 06:38 AM
