Movie clip 1 test drive HSR intake
Old May 19, 2005 | 03:56 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Not sure this it the right forum but....... a short movie from my 1 test drive with the HSR.
1. Same Tune as before (with superram)
2. All other parts where the same, se homepage for info.
3. Procharger unit wasent mounted.
4. TPS was about 70-80%
5. I let of because the road was turning and the rear end was moving
Ps. for some nice projects follow the musclecars link on homepage, under projects...
Movie
Old May 19, 2005 | 07:10 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Sounds good.....what are you running for compression? Sounds fairly high
Old May 19, 2005 | 09:16 PM
klumb15's Avatar
thast sweet...what kind of mods are done? that cam sound nice, whats the specs on that...nice vid but you should remake a longer one...something were we can see what the car can do...
Old May 19, 2005 | 11:33 PM
85_ZED28's Avatar
Car: '85 Z28
very nice!
Old May 19, 2005 | 11:47 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
You can find all the info about the setup on my homepage.
Short engine spec..
415cui
9.0:1
230/244 0.544/0.576 112 lobe
Will record some movies soon when I have the Procharger F1 on and tuned in............
/N.
Old May 20, 2005 | 02:08 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
apparently I'm the only one that can't download the vid?? I'll try again later...
Old May 20, 2005 | 03:12 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Works fine, sounds good
Old May 20, 2005 | 03:22 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
sounds good, can't wait to see a longer video
1992rs/ss
Jan 31, 2025 05:10 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
gta power
Aug 13, 2015 06:15 AM
