Is there a fix for yellow clear coat on wheels?
Old Apr 7, 2006 | 07:15 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
I bought a nice set of 16" formula wheels this winter. They don't have any curb rash or pits. The only problem is that when I cleaned them up the clear coat is kinda yellow and hazey.
I've done a search but all the results were about stripping the wheels and polishing them. I would like to know if there is any way to save the clear since it's not peeling or pitted. Can I wetsand the wheels like you would wet sand the clear coat on regular body parts? Is there some kind of polish that would take off a thin layer of clear coat? Is the clearcoat probably yellow all the way down to the metal where I'll just have to bite the bullet and strip the wheels?
Old Apr 7, 2006 | 08:07 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
you didnt happen to use a cleaner on them did yah...i used simple green on my wheels once and ruined the clear coat it went all foggy and whiteis yellow also.
do a search for polishing wheels...yes you proably should strip the clear of em and polish them every now and then.
Old Apr 7, 2006 | 09:24 PM
Engine: 305 LG4
All I did was wash the real good with the car soap and warm water and a sponge. I really don't have the time right now to spend 4 hours per wheel stripping them and then polishing them. I was hoping to be able to bring the clear coat back to life since it's not peeling.
Old Apr 8, 2006 | 08:07 AM
JB22's Avatar
Yeah, only way to fix it now is to strip it off.
Long tedious process, but worth it in the end.
Old Apr 8, 2006 | 02:19 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
stripping it only took about 2 minutes for me...i sprayed aircraft stripper on, let it sit for about 15 minutes, the fired up the power washer and off she came! looked 10 times better just with the clear off
Old Apr 8, 2006 | 04:13 PM
Engine: 305 LG4
I've stripped wheels before and I know that it doesn't take that long. The hard part is properly polishing them. That requires some time invested to do a good job. I don't really have the time right now and I don't want to do a quick half a$$ed job. If I can't do anything to make the clear coat look better short of stripping it and polishing the wheels I'll just leave them as is until next off season when I can take my time a do it correctly.
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Before you go about stripping them, try wetsanding them a bit like you said and see if that gets rid of the yellow. Then apply a fresh clear coat (use engine or wheel paint). It worked on my Mom's van wheels.
Old Apr 8, 2006 | 04:16 PM
Engine: 305 LG4
Do you think spray can clear coat will work ok or should I try wet sanding and then take the wheels to a paint shop and have them shoot them with clear?
Old Apr 8, 2006 | 04:19 PM
3rd gen V8's Avatar
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
Yea i have had better luck with the spary than the big gallon of aircraft striper. But dont forget to use gloves becuase that stuff will burn you skins realy bad, oh and it also says that it is known in californa to cause cancer. But thats only in californa, so you will be fine in any other state lol . But hey what dosent cuase cancer these days?
Old Apr 8, 2006 | 04:42 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
just being in california causes cancer. theyre ridiculous about it.
Frozer!!!
Jan 19, 2024 04:55 PM
diana227vegas
Jul 8, 2016 12:27 AM
86IROC112
Sep 29, 2015 04:07 PM
ZsTransAm
Aug 11, 2015 07:30 PM
