4th gen dash install PICS INSIDE!
Old Jan 14, 2003 | 11:45 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
http://www.cardomain.com/member_page...=283851&page=6
Its in thier.....
PITA!!!!
needs alot more work to make it "factory"
Old Jan 15, 2003 | 06:32 AM
StocRoc's Avatar
lookin good
Old Jan 15, 2003 | 08:05 AM
IROCKER's Avatar
Very nice!...Total time...how long did it take you to do?
Old Jan 15, 2003 | 08:14 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
So do you have any hair left?
Yeah, I know it is a pita to do a dash swap. And I just went from 89 to a 92 dash. Couldnt imagine with the 4th gen.
Look good. Do you have the seats to match?
Old Jan 15, 2003 | 08:37 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I swapped out my dash for an 85-92 bird dash, and with the help of a friend I had it done in about 2 hours. It was surprisingly easy, actually. My 83 cluster bolted up just fine to the newer style dash, and it even had a hole behind the cluster for the speedo cable, since the dash was designed for 85 birds which still had the cable speedo. I wouldnt say it was hard at all, just tedious, there must be 100 little screws that hold everything together.
Old Jan 15, 2003 | 08:48 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Started at 830am pacific time, stopped at roughly 4pm pac time. Took a break for an hour to get some much needed food.
Pullign everythign off the old dash, and figuring out the cluster wiring has been the hardest part.
Speedo doesnt work (wrong wire obviously), cant find the fuel sender wire, also tach IS NOT CALIBRATED FOR A V8, ODO lights up, but doesnt record mialge cuase its ecm controlled.
Old Jan 15, 2003 | 09:00 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Well, I had to remove the dash out of the parts car with a broke windshied. Glass everywere. Then the dash mounts on the side beside the doors were different. So I had to cut the old ones off and weld the new ones on. They guy also had a alarm wired up, so I had to cut and splice the wires. Some of the unit was missing. So I guess I ran into a few problems. But yeah it was not that bad if I had not ran into those certain problems.
Old Jan 15, 2003 | 09:21 AM
FLYNLOW92rs's Avatar
Looks interesting, I would like to try this swap but thus far there isn't a real good tech article.....(HINT.. )
Keep us Posted...
Old Jan 15, 2003 | 11:39 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Looks great! Can't wait to get mine in there.
Old Jan 15, 2003 | 12:25 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Whats up with the old dash?
Old Jan 15, 2003 | 04:39 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
its old and looks liek every other nice 90-92 dash aka doesnt stand out.
Old Jan 15, 2003 | 07:17 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
So what are you guys doing about the trim piece on top of the dash, triming it down?...any pictures of that yet?.....
Old Jan 15, 2003 | 08:24 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
I will be trimming it down to fit, but i want to finsih up the wiring.
So far:
Speedo: Cant get it to work, might be beacause im nto exactly sure on what wire it is on the third gen side
Fual Guage: Same as above
Lights: have no clue......
Odo: Lights up with 73k on it, but thats about it lol
Rest fo the guages work (albeit the tach is off, its not claibrated for a v8)
Old Jan 15, 2003 | 08:33 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
You have the 145 speedo for sale????
Old Jan 15, 2003 | 09:40 PM
A few questions for ya??
What are you gonna do about all the holes i see in that dash (air bag area, HVAC, etc)
How much for the dash and how much you pay for it?
Old Jan 15, 2003 | 10:23 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
air bag cover, dash pad, dunno bout the hvac controls, maybe fab up somthign to go thier.
Old Jan 16, 2003 | 11:55 AM
BOTTLEDZ28's Avatar
Transmission: A4
Custom X that looks pretty custom . I started to laugh when i seen the pics. They look just like my swap. do you have power mirrors, i dont and the **** comes very close to the side of the dash. What did you end up doing with your fuse block. I used my old bracket and modded it some and bolted it back to the frame of the dash. it sits in the same spot as it was. I forgot all about that stuid buzzer box. Im gona have to jam it up under the dash somewhere. also, after doing my swap, my buzzer wont shut off unless i put my seltbelt on . any ideas on this one.
the wire on the 3rd gen harness for the fuel gauge is the purple wire on the left connector. it should be the 4th wire in from the inside on the top. let me know if thats it. I just traced out the contacts from behind the cluster to the 2 plugs and then made a diagram of them.Did you say your lights werent working or the cluster lights werent? i think all the cluster lights are grey wires. Keep me informed. I have a huge Chiltons book for the wiring on our 2 cars. let me know what wire you need desribed and i will look it up
Old Jan 16, 2003 | 12:06 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Hmm the purple on the left one hmm... i thought i tried that one for the fuel guage.....guess ill re try it.
Which wire is speedo hookup?
Ya the dash lights, thiers 2 wires, ip illumination and odo illumnation on my new cluster.......
As for the seat belt....i just left the wire disconnected, grounded the abs wire and i still need to groudn the security wire.
The fuse block will be jamed/bolted/ziptied underneathe one of the knee bolsters i think, havtn goten that far, been tryignt ot idy evwerything up, measure for the dash pad cut, extened stereo wiring etc.......
yes i have power mirrors i also noticed the vents are awefully close to the door's arm rest.
Old Jan 16, 2003 | 12:12 PM
BOTTLEDZ28's Avatar
Transmission: A4
Hmm, the speedo.. i did not see any iwre listed for thaton the connecter, if you trace the wires on the back of the cluster the speedo and tach go into a seprate circuit board or something. I have a t56 and the SGI 5 box so i took the grn/wht wire on 4th gen harness and plugged that into the box, im gonnahave to mess with it when the cluster gets here later today.
Old Jan 16, 2003 | 12:49 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
what wire on the thirdgen side is hooked into your sgi 5?
Also....i have an SGI 5 brand new in box for sale, askign 87 shipped, exactly what i payed for it.
Old Jan 16, 2003 | 12:59 PM
BOTTLEDZ28's Avatar
Transmission: A4
with my old dash, I had the + on the t56 connector plugged into the SIG IN. I then cut the T5 connector off and put the + wire into the OUT 3. the ground wires from the t5 connector, t56 connector and the box where all grounded. PWR, is coming from the ACC in fuse block.
Now I have to figure out how get get it to work with the new cluster. I read on another post that the grn/whte wire on new cluster had to go the SIG IN on the box. That leaves no place to put + wire coming from the tranny
Old Jan 16, 2003 | 01:06 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
woudlnt the green/white one be output since its the speedo input for the 4th gen guages?
Old Jan 16, 2003 | 01:09 PM
BOTTLEDZ28's Avatar
Transmission: A4
ya thats what ihave been saying to myself. I will have to see what happens with a few different setups
Old Jan 16, 2003 | 10:00 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Ok, well ive coem to the conclusion the ls1 fuel guage must be computer controlled...cus it just wont work for me lol
Speedo......i dunno im goign nuts over it........
Old Jan 16, 2003 | 10:12 PM
BOTTLEDZ28's Avatar
Transmission: A4
Man that sucks, is there any way to know for sure if its computer controlled, I cant why and how a fuel gauge need to be controled my the ECM.I hope I dont have this problem cuz I'll have to do what the nascar drivers do and watch my fuelpressure gauge for pressure drops. Been there and done that before. Custom can the dealer get you a printe diagram of the cluster?
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
