4th gen gauges
Old Feb 23, 2004 | 11:36 AM
91zconvt's Avatar
Car: 87 Iroc
4th gen gauges
Hey, finally about to bolt up my '99 camaro dash, but I have a question first. I just bought a gauge cluster out of a 97 z28. It's cool, it's got that white overlay with the flames and stuff...ANYWAY, All I need now is the harness that plugs into the cluster. Question is, do I need the harness from a '97 car or will other years, or even a trans am harness work? I'm only looking for the harness with a little wire left to it. I don't want the whole harness. Just need to splice it in.
Any help would be appreciated. Called all the local yards, and none have a '97 z28 or any of the harness from one.
Old Feb 23, 2004 | 02:35 PM
Faded's Avatar
Car: '91 Firebird
I'm not sure about harness compatability, but it took me awhile to find just the harness for my 95 z28 gauges. Nobody wants to chop it up, but just sell it as whole.
Check out the boards at camaroz28.com, theres lots of 4th gen people over there, and its where I found my harness.
Old Feb 23, 2004 | 10:04 PM
91zconvt's Avatar
Car: 87 Iroc
ttt
really need to know what I have to buy
Old Feb 23, 2004 | 11:40 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Youll need the 97 harness i believe. I did the full swap of a 98z into my 90 about a yr, yr and a half ago myself.
You can use other newer yrs, but get a harness diagram to make sure the colors are the same.....or since you dont have one at all then youll know which pinout is for what
Old Feb 24, 2004 | 09:43 AM
91zconvt's Avatar
Car: 87 Iroc
does the model matter? I was hoping someone with the wiring diagrams could help me out.
Old Feb 24, 2004 | 09:50 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Im not sure to be honest. As ive never really taken apart say a v6, firebird, ta etc 4th gen dashes, but id think theyd all be the same. as in smae number of wires coming off the plug......
Old Feb 24, 2004 | 03:15 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I will be useing a 95 v6 firebird harness for my 2002 firebird v8 guages. The wires from my 95 harness also match up to the wires that I think it was CustomX posted for his 98 camaro guages about a year ago.
Are the '97 camaro guages like the 98-02 guages in appearance? If so then I am almost sure that you can use any year firebird harness or 98-02 camaro harness for the guage cluster. Any of those should just plug right in. You may just need to just change some wires around in the plug.
Old Feb 24, 2004 | 09:22 PM
91zconvt's Avatar
Car: 87 Iroc
alright, what I'm gonna do is just go out and get any harness I can find, then I'll draw a little picture of the harness with a chart of all the wires comming out of it, and if you could, just confirm that they match yours? Just want to make sure that when I wire up according to the wiring color chart diagram things that they're actually going to the right things and not just the right wires, know what I mean?
Old Feb 25, 2004 | 02:50 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
Heres Customx old post. it might help you. its got the pin#, wire color, and function. https://www.thirdgen.org/techbb2/sho...hreadid=152340
Old Feb 25, 2004 | 08:14 PM
91zconvt's Avatar
Car: 87 Iroc
thanks, that's what I needed
Old Feb 25, 2004 | 08:46 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
1999-2002 F-bodies switched to a 240-40 ohm fuel gauge instead of the 0-90 ohm ones used in ours. How do you plan to get around that?
Old Feb 25, 2004 | 08:49 PM
91zconvt's Avatar
Car: 87 Iroc
you're not talking to me, right? I'm using a 97 cluster. Speaking of which, I'm gonna need a Dakota digital box thing (can't remembe the name right now) for what? The tach or speedo? Or am I gonna need one for each?
Nevermind...Just saw that John5.7 is using the later gauges
Old Feb 25, 2004 | 08:53 PM
3rdGenSS's Avatar
Car: 91Z28, 94 Silverado, 99Z28
Engine: 350 TPI, 350 TBI, LS1
Transmission: 700R4, 4L60E, 6-speed
Axle/Gears: 3.42, 3.42, 3.42
you will need the SGI-8 box for your tach.. nothing for your speedo.. it wants the 4000 ppm and you have that in the 91 already.. the tach is wanting 4 cyl pulse and you will be feeding it a 8 cyl pulse so you will read about 50 to 75 percent high.
Old Feb 25, 2004 | 10:29 PM
91zconvt's Avatar
Car: 87 Iroc
That's awesome about the speedo. However, the 4cyl tach thing, I thought that was jus for he LS1 gauges? I have '97 Z28 gauges, in 97 it was an LT1. I'm assuming I still need it anyways, just wondering.
Old Feb 25, 2004 | 10:59 PM
3rdGenSS's Avatar
my bad.. that is right.. it is for the ls1.. yours as long as it is from an lt1 you should not need the box at all...
Old Feb 26, 2004 | 11:34 AM
Transmission: 4L60e
Axle/Gears: 9 bolt
I am going with an Autometer guage in my air vent. But there is a way to remove the 240 ohm guage and replace it with a 0-90ohm in the cluster.
Old Feb 26, 2004 | 11:39 AM
91zconvt's Avatar
Car: 87 Iroc
If that is true, you just made my day...
Old Feb 26, 2004 | 12:31 PM
3rdGenSS's Avatar
yes.. the fuel gauge can be replaced by a 3rd gen gauge so it will work.. im useing the 98 cluster but it is v6 so it will work without it.. but the ls1 you have to change it.. just get one out of an older car with the same sweep. you will be good then.
Old Feb 27, 2004 | 03:04 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
Its been a long time since I read the article I saw it in and I can't find it right now, but is it as easy as pulling the old one out and puting the 3rdgen one in? Or is there more to it? because I think I remember it saying that theres some kind of soldering to the board involved.
Old Feb 27, 2004 | 05:24 PM
3rdGenSS's Avatar
yea.. you have to solder the new one in after you take the one off.. there is 4 post on the ls1 but one isnt used...you should be able to see what it needs.. ill have to see if i can find the post on it
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
cam-mike
Aug 24, 2015 07:23 AM
