Hatch pull down...cant figure out this wire
Old Oct 12, 2005 | 08:18 PM
unklechuckles19's Avatar
Car: 1987 Z-28
Engine: 355
Axle/Gears: 10 Bolt/3.23 peg leg :(
can someone tell me where this white wire goes, the single one off to the right? its on an 87 hatch pull down motor. i cant figure it out, i remember pulling it out of somewhere but i cant remember where it went PLEASE HELP!
i did do a search, but didnt turn up anythign that could help me.
Attached Thumbnails Hatch pull down...cant figure out this wire-pa120004.jpg
Old Oct 12, 2005 | 10:15 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Don't know if it's the same as an 87, but here for a 91:
Old Oct 12, 2005 | 10:25 PM
Car: 1987 Z-28
Engine: 355
i have that, and i tried using that, and all it did was make my brain hurt. i couldnt figure out which wire it was...thanks for your help tho!
anyone else?
Old Oct 13, 2005 | 12:20 AM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
the other end to where that white wire plugs into should be there somewhere....i remembering replacing mine about a year or 2 ago....did you try installing it & then seeing if you could find it out? sometimes that helps....does your trunk have a light in it like the 91's?
Old Oct 13, 2005 | 12:42 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
dont those wires belong in the car? with the rest of the wiring harness?
and is that even for the hatch motor? if i recall my 89 had a small 4 wire connector
maybe thats where it branched off.. thats probably all the wires for hatch motor, power release, and light i take it?
yeah its probably for the light (the light is probably on the trim panel if your scratching your head trying to find it)
Old Oct 13, 2005 | 09:57 AM
Car: 1987 Z-28
Engine: 355
the motor is an 87 so its a little dif. then the 89-up ones. i know where the other wires go, they go into a black relay box, ive got them im there fine. this is off my old unit that doesnt work, and ive got my new one in and hooked up, i just dont have power to it. i was wondering if this wire hadanything to do with it, it'll lock the hatch, and release, but it wont pull down. ive read though Lon from TDS's posts and it seems like ive done everything he says, but i dont know wtf is wrong. do camaro's have the 2 fuses like the firebirds do for this thing? perhaps that could be the problem?
Old Oct 13, 2005 | 11:04 PM
Engine: 283
so your new hatch motor DOESNT work??
if thats the case,id be checking fuses......
Old Oct 14, 2005 | 12:54 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The white wire in question isn't plugged into anything on your 1987 model year car. In 89 or 90 GM changed from a manually switched hatch light to one that is turned on and off by the hatch pull-down unit. In those cars (as I recall) it connects to an orange with white stripe wire. Bottom-line, that white wire in question has nothing to do with why your pull-down isn't working.
Did you check for power at the red with white-stripe wire that connects to the blue wire? Next to check is that the ground wire is connected to the ground location below the hatch pull-down unit. If your wiring has been cut, then you're probably better off replacing the striker-sensing switch.
The only functional difference between the 86-87 and 88-91 pull-down units is the connector on the blue wire. Yours has a large white connector. The 88-91 has a much smaler black connector on the blue. wire. Some people make the mistake of plugging that white wire your questioning into the blue wire.
There is one fuse and relay for the pull-down unit on Firebird and Camaro and another fuse and relay for the hatch solenoid release.
Lon Salgren
Top-Down Solutions
Old Oct 14, 2005 | 01:27 AM
Car: 1987 Z-28
Engine: 355
thanks for the whole explination Lon, i was hoping you'd chime in at some point! i have no classes tomarrow, so i'll take a fine tooth comb over everything and see what i can do!
thanks for all the help guys!
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
madsv1000
Aug 20, 2015 06:45 AM
