Any ideas on how to mod the overhead console?
Old Jun 14, 2006 | 05:43 PM
Firebat's Avatar
Looking for pics or ideas to modify the overhead console. Mainly, something to replace the dials and the leather pocket.
Old Jun 14, 2006 | 06:00 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Im interested to see what there is out there myself.I hate that thing and every time someone gets in my car theyre like what the hell is that and what is it supposed to do.I like the leather pouch though,Its perfect to hold my smokes
Old Jun 15, 2006 | 01:00 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
someone made a plate for the different switches they needed that went in place of the dials. As far as the pocket thats where i stash my stereo remote. But yeah i'm gonna replace those dials with something cause i get the same stupid questions.
redraif did it but i don't like the switches she used.
Old Jun 15, 2006 | 01:34 AM
Zonda Man's Avatar
Car: 1991 Firebird with T-Tops
Engine: L03 - 5.0L 305
what overhead console ?
Old Jun 15, 2006 | 06:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link:
https://www.thirdgen.org/forums/faq-...oth-types.html
JamesC
Old Jun 15, 2006 | 09:14 AM
Firebat's Avatar
well, look at what other cars have. Some have a display with outside temperature and an electronic compass in their overhead console.
Old Jun 15, 2006 | 10:11 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I hated the switches myself... at the time that was all I could get my hands on... I have now gone to the round style with a simple dot led to let you know when they are on... Much cleaner... working on the swap over now... will have to post finished pics later... might be a while though we have been doing some performance and clean up on the engine bay, so that comes first!
Old Jun 15, 2006 | 10:18 AM
redraif's Avatar
The only problems, which is the same problem i am having with the switches, is space! There is not much room in the console and there is not much clearance in the roof. The wires going to my switches are making it hard to get the darn thing to mount!
The switches are actually controlling bout everything I have aftermarket on the car now... Nitrous, Kitt light, Interior neons, exterior neons, fog lights, strobes... so now I can have it all clean and uniform. Anything extra I can add back to the dash at a later date. I have been trying to rig the factory fog light switch to work my fog lights, but have not found the perfect combo just yet. Now that I have a bit more relay knowledge then before, I think I might get back on it! Then I will have an extra one i the roof for a Nitrous purge or bottle blanket! LOL!
Old Jun 15, 2006 | 11:37 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
haven't seen you post in awhile redraif good to know your still here.
as far as wanting a compass and stuff you should get one of these and try fitting it into place. Digital Car Compass and Indoor / Outdoor Thermometer
if i had the money to spare i'd try it.
i don't know how big the dial panel is though but there are loads of those things on the internet.
Old Jun 15, 2006 | 03:08 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
LOL! It warns you about BLACK ICE conditions
Old Jun 15, 2006 | 03:30 PM
redraif's Avatar
Yep still around... Got tired of some on the imature behavior of some and had been off for a bit. Fig I would work on the car instead... so then I got to updating the site with the new performance mods and just check in now and again!
Old Jun 15, 2006 | 05:21 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i have done this. used four rocker swithces. they do the following, from left to right:
1st: on/off toggle. toggles secondary fan.
1st LED: RED. on when 2nd fan is on
2nd: on/off toggle. Brake lights toggle. with switch "off" i have no brake lights when i press the pedal.
2ND LED: unused.. yet.
3rd: on/off toggle. tourqe converter lockup. with switch "on" my tourque converter locks.
3rd LED: was suposed to be for tourque converter but i wired it wrong, so nothing
4th: on Momentary. with switch held in "ON" position the brake lights come on. regardless of pedal position or 2nd toggle position.
4th LED: on whenever brake lights are on
Attached Thumbnails Any ideas on how to mod the overhead console?-switches1-small.jpg   Any ideas on how to mod the overhead console?-switches2-small.jpg
Old Jun 16, 2006 | 01:04 AM
fadetoblack's Avatar
Car: 1990 Formula
Engine: 383 Stroker
Check out this thread about the pockets.
https://www.thirdgen.org/forums/body...d-stock-o.html
Old Aug 21, 2006 | 04:03 PM
Untamed's Avatar
Car: 88 Trans Am
Engine: 305 TBI
I'm resurrecting this thread because I'm in the process of looking for a t-top overhead console. I'd like to remove the dials and put an outside air temp / direction digital gauge in its place. This was suggested above however I haven't seen anything yet that would fit the small-ish space. Plus I'd like the readout to be red numbers or red background with black numbers to match the red lighted interior of my Trans Am at night.
Anyone have any product suggestions? Any installation suggestions?
Old Aug 21, 2006 | 06:06 PM
Firebat's Avatar
No product suggestions on the top of my head. Its an electronic circuit that wouldn't be too hard to build though, might even be schematics for it on the web. Need a temp sensor, some analog to digital convertor or equilvalent circuit, then use 7-segment red led displays as the output.
Old Oct 22, 2011 | 06:32 PM
coreys90iroc's Avatar
Car: 90 Iroc
Transmission: 700r4 Built by- Speed Secrets
Re: Any ideas on how to mod the overhead console?
why would you want your brake lights to turn on by a switch? not to be rude just wondering, did a good job!
Casey Meyers
Mar 2, 2016 10:46 AM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
mav75
Aug 31, 2015 12:16 AM
TheJoeY88
Aug 13, 2015 06:51 PM
mx127
Aug 10, 2015 08:13 AM
