Ghetto paint fix??
Old Dec 9, 2007 | 04:07 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Ghetto paint fix??
The clear coat on my Rs is pretty much SHOT its comin of faster thatn i can keep track of because of all of the rain that recently hit us, and i was complaining about it and my dad said to go out with a tube of superglue, and start putting it under the endges that are peeling, would this be a good idea? or would it be easier on me to just scrub the old apint and prime the beast?
Old Dec 9, 2007 | 04:12 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Ghetto paint fix??
sounds like a bad idea, you'd be creating more work for yourself in the long run because getting superglue off wouldn't be fun. Id vote scrub the peeling spots and spot prime it.
Old Dec 9, 2007 | 04:41 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
sooooooo....cut my losses and prime it?
Old Dec 9, 2007 | 04:49 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
thats just what I'd do, but maybe someone else has an easier way. you could just let it keep flaking off... Id say depending on how cold it is where you live and how much time you have to work on it. Ive never heard of the super glue thing though.
Old Dec 9, 2007 | 05:35 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Pressure wash it all off, That is what I did, Problem solved. Then buff and polish it and you are good to go!
Old Dec 9, 2007 | 05:52 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
yeah i'm just gonna prime it, i'll probably get on it in a few weeks once i start generating an income again, after i shattered my ankle joint i couldnt work so now i cant even afford primer lol But oh well it'll be a great saturday project
Old Dec 11, 2007 | 11:57 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Just remember primer will absorb moisture. A rattle can of duplicolor or similiar over the primer will protect the sheet metal longer than just primer.
Old Dec 11, 2007 | 02:57 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
what? not true, primer can be left in all weather, Ive left my car in omni mp282 primer in the rain with no problems, and I know many people who have too, it just has to be wet sandable primer.
Old Dec 11, 2007 | 03:48 PM
Stephen's Avatar
Car: 87 GTA
Go by a sign shop, and see about finding some blue vinyl to match your car. It looks like your car is a Marina Blue. My wife's 90 RS was that blue, and the roof started that.
I worked at sign shop anyways, and found a blue that was close, and used it to cover a peeling part with it, including some of the good part, for good anchoring.
It stopped the peeling, until paint day came. You can get good 6 year vinyl, that's all I use, for my vinyl decals, so it'll last without fading or turning white.
Old Dec 11, 2007 | 09:18 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Rattle can primer will work good temporarily, but it will eventually absorb water. Also, it will come off on your clothes if you lean on it or something.
A little more expensive idea, but much better, would be to go to your nearest auto body supply store, get a cheap HVLP gun and a few quarts of Gray Epoxy Primer. It looks like regular primer, except with a little more sheen like semigloss paint. It hardens up good, and seals against water permanantly. It will even seal over rust.
Old Dec 11, 2007 | 09:35 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
at the very least, you want a 2k primer, or an epoxy primer. try mp170,171, and 172 for omni epoxy primers, and mp175 for the hardener.
a regular primer without a sealer will absorb moisture much quicker than a sealed surface.
Old Dec 11, 2007 | 10:01 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
couldn't you just wet sand the clear off then re clear it?
Old Dec 12, 2007 | 03:09 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
I agree with using the epoxy primer. Before I painted my TA I sprayed it in PPG DP epoxy so it wasn't multicolored. It was outside for about year and frequently driven and it was fine. Just resanded it and sprayed it with PPG K36 primer/surfacer/sealer before the basecoat. Rattle can primer sucks, and sometimes doesn't fare too well with different brands of paint. As far as reclearing, I tried this a few years back with mixed results. I did it on a fender of a buddies car and it turned out just fine, just a lot of work. I tried it again on a different car, and at the edges of the old clear the new clear would bubble.
Street Lethal
Apr 30, 2019 12:14 PM
SlowAZ28
Members Camaros
Aug 31, 2015 07:53 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
WIzmo
Aug 30, 2015 02:30 PM
neekolzun
Aug 24, 2015 04:59 PM
