urethane primer and humidity?
Old May 29, 2008 | 07:30 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
my car is about 95% ready for primer so i would like to spray it saturday...the only problem is that it is going to rain saturday and sunday. i have a clean garage so the car will stay dry but will the humidity in the air effect the out come of the primer. by the way it is maxx fill 2K urethane primer if that makes a difference.
Old May 29, 2008 | 08:12 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: urethane primer and humidity?
I'm not familiar with that particular primer.That question would probably be better answered by the manufacturer.
Old May 29, 2008 | 08:23 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
It shouldn't make much of a difference. You may notice that it will "swell up" around areas where there is filler underneath, but if given enough time to fully cure before sanding for paint, it will be fine.
Old May 29, 2008 | 08:29 PM
jay92,85,79's Avatar
Car: 85z28,
It will be fine.. Body shops don't close when it rains.
Jay
Old May 29, 2008 | 08:38 PM
Engine: that I like
Jay
Lol, Why didn't I think to say that
Old May 29, 2008 | 10:32 PM
Car: 85z28,
i wish that it was not true so i can get some time off lol
Old May 30, 2008 | 06:35 AM
irockid86's Avatar
Car: 88 iroc camaro
Axle/Gears: stock
i did think about the fact that body shops dont close when it rains. but i figured having heat and ac to control the temp would also control the humidity for the most part. so i will probibly spray it and just wait to block sand. i will let you all know how it goes.
Old May 30, 2008 | 10:47 PM
Norwood's Avatar
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
Just remember that urethane paints harden faster with increased humidity. You will be ok if you adjust your reducer accordingly to compensate.
Old May 31, 2008 | 01:00 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Use the right temp reducer too.
Old May 31, 2008 | 07:06 PM
irockid86's Avatar
Car: 88 iroc camaro
Axle/Gears: stock
i didnt get to spray today i ended up doing a little scuffing on the rear hatch jam? i wasnt planing on doing it but then i decided to so i had to tape off a lot more and you all no how it goes from there.
1992rs/ss
Jan 31, 2025 05:10 PM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
92GTA
Apr 9, 2016 07:39 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Catcher55
Aug 15, 2015 07:08 PM
