door not lining up right
Old Mar 5, 2009 | 12:03 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
i know im kinda behind on this but last spring/summer i was having shifter cable problems with my 82 which resulted in the car poping out of park into reverse when the driverside door was open. well ittook off and caught on my engine hoist and bent the door backwards. i have sinced repaired my fender enough so i could open and shut the door without it catching and massaged the door back to where it looks "ok". well on the rear of the door it doesnt line up right the glass is about an inch from sealing. ive unbolted hinges and tried to shift door around but no dice. i need to replace that fender anyway so once it warms up i plan to pull both doors and fenders and start some body work. is it a poibility the hinges are bent? can i buy new ones? not the pins. if so ill just get another door but parts are getting hard to find around here now. anyway thanks for the help in advance. im goin to get pics now to upload btw.
Old Mar 5, 2009 | 12:07 PM
Stephen's Avatar
Car: 87 GTA
Re: door not lining up right
Most likely, the body sheet metal where the hinges mount, is tweaked. Its softer & bends easier, than the thick hinges themselves.
Old Mar 5, 2009 | 12:24 PM
Screamin86's Avatar
any idea on how to fix this problem? before the doors never sagged always shut solid with no rattles and sealed up good.
Old Mar 5, 2009 | 01:32 PM
Screamin86's Avatar
here are some pictures
Old Mar 6, 2009 | 01:55 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
I had to read that a couple of times to get it lol. More than likely the hinges are bent, do you have better piictures of where the hinges are?
Old Mar 6, 2009 | 01:59 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Damn ! all that from the HOIST ?
Old Mar 7, 2009 | 12:19 AM
Screamin86's Avatar
well yeah the hoist and my leg i was standing next to it when it happend. got a pretty good bruise from it and a limp for a few days. ill try to get some more pictures tomarrow.
Old Mar 7, 2009 | 10:45 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
I posted some info in this other thread that might be helpful.
https://www.thirdgen.org/forums/body...-do-i-fix.html
Old Mar 7, 2009 | 10:49 AM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
you may have to unbolt the door and weld in the right spot to get it right again. ive done it before. its not fun, but it fixed it.
Frozer!!!
Jan 19, 2024 04:55 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
AkDrifted
Aug 17, 2015 07:45 PM
