Can I use this B&M Hammer Shifter Knob On my Stock Auto Shifter?
Old Jan 12, 2002 | 08:05 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Can I use this B&M Hammer Shifter **** On my Stock Auto Shifter?
B&M Hammer Head T-Handles
The same ergonomically designed handle featured on the Hammer shifters. Fits your hand comfortably and features an aluminum or black finish with adapters for most popular SAE thread patterns.
130-80742 83-96 F-body/Mustang, Aluminum $ 32.99
www.jegs.com
Old Jan 12, 2002 | 08:08 PM
D-ROK 420's Avatar
if u have an auto, the handle probably won't work. I'm not sure how you would disengage the shifter.
Old Jan 12, 2002 | 08:14 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
aw, that sucks cuase the hammer shifter is 200 bucks, i might try it and if it doesn't work, try to return it. any suggestions would help
btw-here is a pic of the actual shifter:
Old Jan 12, 2002 | 08:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, you can't use an aftermarket **** on a stock shifter.
Old Jan 13, 2002 | 07:23 AM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
Not totally correct... There are aftermarket shift handles designed with the push in button like our cars use. And... I guess you could use a Hammer handle if you don't mind having the reverse lockout pushed in all the time (meaning no protection from inadvertantly locking up your tranny while the car is still in motion... nasty... ).
Rob
Old Jan 13, 2002 | 09:36 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
what if you put in the actual b&M shifter or any other aftermarket shifter, wouldn't it still be like that?
Old Jan 13, 2002 | 12:58 PM
ops32's Avatar
Are you referring to the reverse lockout? If so, aftermarket shifters have designed that into their designs. That's what the small t-handle in front of most aftermarket shifters is for - pull up on it to move the shifter out of park, into reverse, etc. In forward drive positions the aftermarket shifters usually ratchet (or something similar) so you can manually shift, one gear at a time, without any chance of accidentally shifting into reverse or park.
If you want to add something to the factory shifter, you need to take the lockout feature into account. There are aftermarket "T" handle shifters (just saw a faux carbon fiber one on this board) that have the push button.
Rob
Old Jan 13, 2002 | 01:09 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
thanx for your help, i am going to try to do some more researh and try to find a way to do this. what about a little lever on the stick, i have seen people have done this, is this posible?
1992 Trans Am
May 10, 2023 07:19 PM
BewleyBizzIROC
Feb 3, 2020 09:52 AM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
NBrehm
Aug 25, 2015 11:49 PM
