Hatch alignment and pull down
Old Sep 13, 2023 | 03:37 AM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
I replaced my hatch some time ago and have just realized that it was grossly misaligned. So I took the Struts apart and got it straight. Got the dirt out of the tracks and stopped thee water from running into the trunk area. Went to put the hatch back down and noticed the pull down latch mechanism would not catch. Upon further inspection i see there is a ton of play in the tracks that the latch system rides in. In particular the drivers side. So much so that the latch flops and leans toward the front of the car (toward the front of car). I adjusted with my hand leaning it towards the license plate like it's supposed to be and voila. How can I tighten THE TRACKS that the latch system rides in to keep that latch STRAIGHT UP AND DOWN????? Every time all the time. Once aligned it works great..
91rs stock
Old Sep 13, 2023 | 05:31 AM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: Hatch alignment and pull down
I think this is what you need, https://www.top-downsolutions.com/ha...ro-or-firebird) and look at Lon's rear hatch parts, it sounds to me like you need new guides.
Old Sep 13, 2023 | 05:56 AM
Car: 91RS
Link not working, but thank you for the swift reply
Old Sep 13, 2023 | 06:01 AM
Car: 91RS
I did some digging at TDS
found this:
Old Sep 13, 2023 | 08:04 AM
Engine: 5.7 L98
found this:
I think you just need the guides but I have used the deluxe kit to rebuild mine as it was broken, has held up really well.
Old Sep 13, 2023 | 10:42 AM
Car: 91RS
Thk u a ton
Old Sep 18, 2023 | 01:43 PM
Car: 91RS
Got the guides and feel confident. I will post results
Old Oct 3, 2023 | 02:07 PM
Car: 91RS
I ended up ordering the deluxe kit from top down Solutions got everything put back together. got everything lubricated put the assembly back on the car. the striker on my hatch is now aligned perfectly it hits the latch dead center like it's supposed to. my hatch light turns off. my release switch unlocks the latch, with the key, and with the switch but the motor will not turn on and go down or go back up. and that's with the relay reattached both the black ground wires the small ones reattached. although I got some arching from the really small ground wire I don't know where it goes to but when I connected it to the body I got a little bit of arching. I attached the two wires that I had to unplug one is black and orange going to White the other is red and white going to Blue my unlocked solenoid for the hatch release switch works perfectly I have a big ground wire going from the hatch release solenoid to the actual body right up underneath the latch assembly and I have my wiring harness hooked back up to the motor and the motor plugged back in. I don't know what that is but I guess it's a computer board that attaches directly to the motor has a screw that keeps it in place. there are no fuses blown. I can't figure out why the hatch won't move up and down
Old Oct 4, 2023 | 08:56 AM
Car: 91RS
91rs pull down hatch wiring diagram. Please
Old Oct 4, 2023 | 03:42 PM
Car: 91RS
VOILA.!!!! it helps when u don't put the ball bearing in backwards, sand down the guides a bit, and align the reverse switch correctly. But we got it. All new and lubed
Old Oct 4, 2023 | 04:06 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I had to sand quite a bit off of my guides to make it work
Old Oct 5, 2023 | 06:39 AM
Car: 91RS
10-4 I used an angle grinder and a very very light handed approach hahahahaha
bbsr72
Feb 8, 2025 06:16 PM
ChocolateDS
Nov 6, 2022 05:32 PM
W.E.G.
Oct 30, 2013 06:50 PM
Lmancha96
Mar 31, 2012 03:43 PM
