Parking brake does not hold
Old Feb 9, 2014 | 08:08 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
I have done a diff swap on my 1990 rs drum brakes to a 1989 IROC G92 9 bolt BW 3.42 with discs. I have gotten the cables for the 1989 car and tried them but they seem too long maybe or something isn't right. When I pull the lever it can only be pulled about half way and is really hard to pull. When I pull it as far as I can it still doesn't hold the car on the slightest incline. Anyone know whats going on here?
Matt
Old Feb 10, 2014 | 06:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Parking brake does not hold
82-89 cars have a tunnel-mounted adjuster, while the 90+ are self-adjusting. IIRC, members who tried the swap you mention also swapped the tunnel-mounted adjuster into their cars. My swap into an 85 IROC required the first-design cable, 1460mm.
BTW, for best brake performance, swap in the correct combination valve.
JamesC
Old Feb 10, 2014 | 07:04 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The Delco rear brakes also require retrofitting with the recall kit in order to function correctly. If they've been non-functional for a while, the pistons are apt to seize in the cylinders. This is a common problem with them.
Old Feb 10, 2014 | 07:12 AM
JamesC's Avatar
True. The 89, however, "should" have PBR's.
JamesC
Old Feb 10, 2014 | 02:39 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
JamesC
Ok thanks for the info. So if I get the tunnel adjuster with the 89 cables I should be good to go? And I did do the valve swap with the diff as well.
Old Apr 4, 2014 | 05:39 PM
mark weaver's Avatar
Car: 92 rs, teal, blk int, glass t tops
Engine: 305 tbi
Transmission: t5
Axle/Gears: 3.08
what does PBR stand for?
Old Apr 4, 2014 | 06:18 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Pabst Blue Ribbon
Old Apr 4, 2014 | 06:25 PM
naf's Avatar
naf
Apparently I live in the same world as Gumby.
Old Apr 4, 2014 | 06:43 PM
JamesC's Avatar
The company is Aussi. They make the alum calipers for 89-92 thirdgens.
JamesC
Old Apr 4, 2014 | 07:39 PM
Engine: 305 tbi
Transmission: t5
Axle/Gears: 3.08
back in my day, PBR was a beer also, hehe. thanks to all that took the time to answer my question
Old Apr 4, 2014 | 08:13 PM
naf's Avatar
naf
JamesC
And cheap beer!
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
