JBL problem, JBL owners enter
Old Jun 22, 2003 | 10:16 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
K, finally got my 1200.1 (YEY ) but when I get into my car like to go to lunch it is to hot to turn on....anyone else have overheating problems w/ there JBL?
Old Jun 24, 2003 | 02:50 PM
chevkid's Avatar
Car: 87 SC
Transmission: t5
I have a 600.1 and its never had any problems. Wheres the amp at? Is there enough air around it?
Old Jun 24, 2003 | 10:47 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
its sitting on the gas tank hump...heres a pic...I would think it has plenty of air, and the ground is good, i already checked that.
Old Jun 25, 2003 | 12:04 AM
onebadwagon's Avatar
i cant tell if im seeing this incorrectly, but is your ground smaller than your power wire? if so i would SERIOUSLY recommend changing that.
im not sure on the overheating thing, but im not a big fan of JBL, so i wouldnt be able to help much.
adam
Old Jun 25, 2003 | 12:38 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
If the car was in the sun it can get that aluminum up to around 180+ degrees, which can be out of the heat range of the amp, try getting some type of cover for it or not parking it in the sun
Old Jun 25, 2003 | 11:11 AM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
yeh.....just make some kinda cover for it...black absorbs heat real nice like
Old Jun 25, 2003 | 08:11 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
ok, first the ground is the same size, its just the way the picture is taken. Second, I have to park in the sun, so I will try to get a cover...but wont it get hot under the cover still?
Old Jun 27, 2003 | 06:59 PM
chevkid's Avatar
Car: 87 SC
Transmission: t5
Try to figure out how to run a fan on it if the cover thing doesn't help.
Old Jun 28, 2003 | 12:20 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Ya it will still get really warm. As warm as the inside of your car. The fact that it will be out of direct sunlight will keep it much cooler.
Brian
Old Jun 28, 2003 | 01:13 AM
KhaotikRaje's Avatar
Old Jul 1, 2003 | 12:02 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
I have two amps in mine and the one that sits in about the same place has trouble if I leave the car parked in the sun during the summer. The JBL sits below the deck lid and I haven't ever had a problem. Tinting the back glass can help, or maybe you want to get a cargo area cover.
Old Jul 1, 2003 | 12:32 AM
Car: 89 Camaro RS
Engine: 2.8L V-6
I threw a white shirt over the amp for now and it works fine. I am going to build an amp box once I get the distribution block and the highs amp installed. I'll run some fans and things should be fine I hope. On the box though...I want it to have a smooth painted surface when done...so what do I put over the wood to make it smooth? wood filler or body filler or what?
Old Jul 1, 2003 | 01:45 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
If you use MDF, it will be flat anyway. Body filler and wood filler are basicly the same stuff, and work in the same way. I would use the body filler as it's meant for use in a car enviornment and wood filler is meant for tables and chairs and stuff that stays in a temperature regulated enviornment.
Old Jul 10, 2003 | 02:21 AM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
my jbl amp over heats now and then because my trunk gets no air circulation i leave it for a minute tho and it comes back on
Old Jul 10, 2003 | 09:26 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
You may also want to try something like this:
http://shop.store.yahoo.com/bsless/pbfc.html
Cleotiz
Jan 6, 2018 08:56 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
theurge
Aug 21, 2015 12:46 PM
Fronzizzle
Aug 17, 2015 02:52 PM
