plywood or MDF?
Old Mar 11, 2004 | 04:14 PM
no_car_yet's Avatar
plywood or MDF?
whats better for a sub box? pine plywood, or MDF?
Old Mar 11, 2004 | 04:23 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
mdf
Old Mar 11, 2004 | 04:54 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
definately mdf
Old Mar 11, 2004 | 05:29 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
use mdf, plywood would flex
Old Mar 11, 2004 | 05:36 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
MDF is what i would go with...or oak...or concrete
Old Mar 11, 2004 | 06:09 PM
9177's Avatar
Oak is to porus which would be very bad. If you go with any non MDF wood use cabinet grade 7-9 layer plywood. Most people say birch but as long as it is a high grade which also means expensive you sould be ok. it is best to go with MDF as the density of the wood is consistant and the price is way better. Low grade plywoods have knots and hollow spaces in the lamenits and this could produce bad harmonics and vibration.
Old Mar 11, 2004 | 06:37 PM
no_car_yet's Avatar
okay thanks, i am building a box for a friend, and wanted to know would mdf be good(cheap), so thanks.
Old Mar 11, 2004 | 06:42 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I think plywood would do a really good job
Old Mar 11, 2004 | 09:43 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
if the oak was treated it would be alright wouldnt it?? probably not too economical though
Old Mar 12, 2004 | 12:39 AM
Kandied91z's Avatar
your all wrong....use medium density fiberboard.
Old Mar 12, 2004 | 01:54 AM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Right On, Brother.:yourock:
Old Mar 12, 2004 | 07:50 AM
9177's Avatar
Anytime I've built cabinets out of oak the glue always presses out of the ends on the joints. and yes very expensive
Old Mar 12, 2004 | 07:53 AM
Screamin'87GTA's Avatar
Car: Trans Am GTA
Transmission: Rebuilt 700r4 with stage 3
MDF Is ooooooohhhh soooooo heavy, but definitely better then anything else out there! for the car application!
Old Mar 12, 2004 | 09:08 AM
nibleT's Avatar
Car: 1989 Camaro RS
Engine: V8 305
if weight was a problem you could use birch. About $50 a sheet tho
Old Mar 12, 2004 | 06:16 PM
NEEDforSPEED's Avatar
MDF
Old Mar 12, 2004 | 08:37 PM
Scotty562's Avatar
Car: 2001 SS Camaro
Axle/Gears: I should know this
I made my box out of High Densifty Fiberboard, i think thats what my dad called it.
It was just test box though, just so we could get the hang of making a custom box but... it doesnt sound to bad.
Anyone ever make a box out of the stuff?
Old Mar 12, 2004 | 09:15 PM
br()bert's Avatar
Car: 85 firebird
I've heard of it. Never used it though.
Old Mar 12, 2004 | 10:14 PM
br()bert's Avatar
Car: 85 firebird
why not try fiberglass. Imo its easier. Just messier
Old Mar 13, 2004 | 12:37 AM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
heard of what???
Old Mar 13, 2004 | 10:52 AM
br()bert's Avatar
Car: 85 firebird
Originally posted by Kj Rockz
heard of what???
Old Mar 15, 2004 | 03:48 AM
stiers's Avatar
I haven't heard of it. But it it is more dense(heavy) than MDF you can cancel those drop springs you ordered because it is gonna put the rear end down a lot.
Old Mar 15, 2004 | 08:00 AM
Scotty562's Avatar
Car: 2001 SS Camaro
it is heavier than MDF but, not by an insain ammount.
Old Mar 20, 2004 | 06:21 PM
KYL98's Avatar
Car: 1991 Z28
Made my box for my Three L5's out of Birch.....MUCH MUCH lighter than MDF...BUT its hard on drill bits and saw blades...The advantage of it is it doesnt flex like cheap plywood...and its lighter(doesnt make the *** of the car squat). Disadvantage is price(unless your a manager at Lowes)
White Ninja
Car Audio
Sep 25, 2002 09:33 AM
pianiy
Car Audio
21
Aug 20, 2001 03:53 PM
FTC
Car Audio
May 23, 2001 09:06 AM
kiztope
Car Audio
Jan 15, 2001 11:29 AM
Aaron91RS
Car Audio
Oct 5, 2000 06:54 PM
