3 10" JL Audio 10w7
Old 11-05-2004, 12:31 PM
2chey's Avatar
Car: 87 Iroc
3 10" JL Audio 10w7
Anyone seen three 10's in the back of a thirdgen? anyone have pics?
I have three 10w7 out of my old pickup and i need some specs on box size or how to build the box!
Thanks for the help guys
Old 11-05-2004, 12:35 PM
onebadwagon's Avatar
you build a box, by assembling at least 6 sides together, from mdf preferably, i generally, like to use fiberglass resin on the inside to seal the box, if you are unable to get the shape you want, then you can use a fiberglass mat/resin mix, to mold any shape youd like.
no, we have NEVER seen 3 tens in the back of a thirdgen.
do a search, btw,
Old 11-06-2004, 05:48 PM
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
you probably couldnt stick 3 10's w7 in the trunk of a thirdgen without loosin alot of air space...best bet for those are make a box on your back seat....cause you dont wanna under air space them cause then you will loose full capability of the subs..you could even blow one
Old 11-06-2004, 06:02 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
You could put 3 10's back there....just not THOSE 10's. It is possible I guess, but with the depth of those subs and the required air space to run them, i think it would be more efficient to run 1 or 2 of them IMO.
Old 11-07-2004, 12:36 PM
90tagta's Avatar
Car: 1990 Trans Am GTA
Transmission: 5-Speed
If you listen to these replys and only run 1 or 2 let me know cause i would probably be interested in buyin the other one.
Old 11-07-2004, 01:42 PM
2chey's Avatar
Car: 87 Iroc
ummm ok I was told that because of the type of speaker(JL 10w6) I either have to run one or all three... something about Ohms...anyone know anything about this?
Thanks for all the info
Old 11-07-2004, 02:10 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
You could run however many you want with in reason. It's just the fact that JL is using a 3 ohm voice coil. Which means you got to becareful how you get your power (usually there mostly even number ohms). That's why they try pushing their JL 500/1 amp.
Old 11-10-2004, 07:43 PM
HamiltonAudio's Avatar
Car: 1982 Camaro Z28
Engine: hot 355 ci small block
Transmission: built TH350
Re: ???
ur first post called them 10W7's, not 10W6's. VERY big difference my friend. Either way you can get all 3 of them working in the back of a third gen with no problems. I'm not sure where some of the others on this thread get their info....
you can run them in 1 cube per driver with no problems. recommend 1.25, so you have a 3.75 cube box. Glassing the rear hatchwell is all of that and more. With creativity, it would work.
The W6's need 0.75 each optimally (from plenty of experience). No problem with that either....
as for the "ohms" thing. the 10W6 is a dual 6 ohm voice coil. Each driver is then (by math) either 12 ohms or 3 ohms each. Running a trio of 12 ohm loads in parallel = 4 ohm mono (ideal load for bridged class a/b amplifiers). running a trio of 3 ohm loads in parallel = 1 ohm mono (ideal for class d monoblocks).
bmoney
Old 11-10-2004, 07:46 PM
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
well u would need alot of air space for 3 w7s like if you made the box in the hatch hole and even going up onto the rear hump it would work...cause you can barely run 3 12s in the back of a thirdgen with good air space
Old 11-10-2004, 07:49 PM
Re: Re: ???
don't forget sub displacement
Old 11-10-2004, 07:52 PM
Re: Re: Re: ???
yeps. but somehow i think they're w6's, not w7's, which dramatically changes the issue
bmoney
Old 11-10-2004, 08:19 PM
2chey's Avatar
Car: 87 Iroc
sorry about the mistake
Hey I just read all the posts...and when my friend posted the first time he said they were 10w7's.......They ARE 10w6's.
I am getting alot of conflicting info.....most people are saying that 3 ...10w6's will sound like crap in the back of a camaro....Unfortunately I want to use what I have in concerns to speakers.....I just want to make sure they have enough air space....I don't want to damage them.....
Thanks again for all the advise
Old 11-10-2004, 08:22 PM
2chey's Avatar
Car: 87 Iroc
the amp
I also have the JL 500/1 amp
Old 11-10-2004, 10:46 PM
there's plenty of room, but you'll have to put some effort into using it.
adam
Old 11-11-2004, 06:55 AM
Re: sorry about the mistake
Whoever told you they sound like **** has their head up their a$$. The 10W6 (even the older ones) are some of the finest sounding speakers going (and all the big boys in the industry will agree). Have and enclosure fabbed that has the subs facing up in the well, and you'll be HAPPY. I had an install once (changed yearly) that had a pair of 10W6's facing up in the well with a larger 2 channel Lanzar Opti amp driving them. All i can say is that most people thought I had a pair of 15's
Keep those drivers in a sealed box (no matter what the specs say, they suck in a vented enlcosure) Give em about 0.75 each and provide 250 watts per driver and u'll be VERY happy, I promise.
bmoney
Old 11-16-2004, 12:46 PM
h1-vltg's Avatar
Car: 91 Camaro Z28
Engine: LS3
Transmission: 6 Speed
Axle/Gears: 3.71
Ditto to what Bmoney said. I have 3 10w6's in my hatch well facing upwards. And as far as asound quality goes...I competed ithe 1997 IASCA world finals with those subs. In fact I still have them back there and they can still hit hard and are extremely tight.
Old 11-22-2004, 09:03 PM
Kandied91z's Avatar
w6's... same thing for the most part as far as what you'll see. when they become cheaper i'll upgrade to w7's.
Old 11-22-2004, 09:50 PM
shortyjmg's Avatar
Car: 86 sport coup
Engine: 5.0
hey Kandied91z do you got anymore shots of your system. that is a bad a$$ car
Old 11-22-2004, 11:07 PM
Kandied91z's Avatar
thank you.
what kind of shots. there aren't to many as it's pretty straight forward. the setup is for sale in the classifieds though.
Old 11-22-2004, 11:08 PM
Kandied91z's Avatar
here's something..
Old 11-23-2004, 09:41 PM
shortyjmg's Avatar
Car: 86 sport coup
Engine: 5.0
i just wanted to check out your amp rack i need to make sure they dont steal my stuff next time. working on ideas is all.
Old 11-23-2004, 10:17 PM
Boomin Boy's Avatar
Car: 83 z28
Engine: 300hp 355
left handed screws
Old 11-24-2004, 12:08 AM
Kandied91z's Avatar
lol...
take away. it was a project that was conjurged and finished in two days. $300 in materials i can't complain however there's always better ways to do things.
with the airride/nitrous in the rear putting subs back there doesn't work so something had to be done. sounded great but looks wise it could improve and it will.
Old 11-24-2004, 01:36 AM
90tagta's Avatar
Kandied91z, so you rlookin to sell ur JL's. Do you have any details on them.
Old 11-24-2004, 02:56 PM
Kandied91z's Avatar
no... i'm selling the box setup. the jl's are staying unless otherwise.
Old 11-27-2004, 08:14 PM
Pro
Pro's Avatar
Car: 1992 Z28 and 1995 Silverado
Engine: 5.7 TPI and 5.7 TBI to TPI convert
Transmission: 700R4 and 4l60E
Axle/Gears: G80 3.23 and open 3.42
Im running 2 JL W6 eights in parallel (1.5 ohms I think). Kenwood amp keeps nice and cool, and it sounds badass.
I used to have 3 of them in my truck (ran parallel, 1 ohm) and it sounded good as well. The acoustics of a thirdgen must be badass.
I now have 2 polk tens in my truck. When the bass hits it sounds like it's farting. I hate polk.
Old 11-28-2004, 11:10 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
I have 3 10" mtx Blue thunder in the back of my car, I think I figured each had about 1.25 cu ft. take a look at my cardomain site if u want
cheers
blake
Nick Locking
Car Audio
09-30-2015 04:24 PM
zayne0
08-24-2015 07:22 PM
RamAirZ
11-17-2001 10:35 AM
85ws6TA
Car Audio
25
12-16-2000 05:24 PM
Todd 92 Z
Car Audio
09-11-2000 08:24 PM
Quick Reply: 3 10" JL Audio 10w7
