will this box work well?
Old Oct 1, 2008 | 03:00 PM
slowblstr's Avatar
hi everyone. i have been planning a sound system for my car for a while now. im going to run 2 alpine type r 12" with a 1000 watt hifonics amp. i will also be running the type r component speakers. my question is will this box work good? http://cgi.ebay.com/CAMARO-FIREBIRD-...d=p3286.c0.m14 the reason im attracted to this box is because it is ported and i wouldnt know how to build my own ported box. any input would be great.
Old Oct 1, 2008 | 07:12 PM
cdoyle's Avatar
Re: will this box work well?
I've never been a fad of prefab boxes, and boxes need to be made for the speaker. Do the speakers you want require a sealed or ported box? How much air space per speaker?
Ports also need to be a certain size, etc depending on the speaker.
Plus the one you linked to is for 8's not 12's.
Old Oct 1, 2008 | 07:38 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
there was a pretty good set of plans floating around the boards before do a search and you can probably find it boxes are not very hard to build with the plans right in front of you
Old Oct 1, 2008 | 08:05 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I bought a similar box off ebay but it was around $75. Sounded amazing with 2 10" infinitys.
Old Oct 2, 2008 | 12:22 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
That box is sweet if you ask me. You should consider a set of Fi or Soundsplinter 8inchers instead of those 12's.
Old Oct 2, 2008 | 05:38 AM
hellsatan's Avatar
Car: 89 IROC
The boxes on ebay are actually built very well. I had one for my first box and loved it. The only thing I didn't like is the way it sits, I wish they sold ones that sit inside the well and instead of sticking out like that. It also makes your license plate and stuff behind it rattle much much more then inside the well type box.
I doubt there would be enough room to add ports.. two 12s on my ebay box takes up basicly the whole thing.. (your link has 8" holes)
It will probably pound with two type R 12" even in a sealed box.
Old Oct 2, 2008 | 09:38 AM
slowblstr's Avatar
yeah i didnt realise that the box was for 8" subs. dumb me. lol anyways, im not sure if i should go with the 2 type r's or 1 type x. either way it will still be powered by 1000 watts rms.
Old Oct 3, 2008 | 02:41 AM
I vote for a single 12in Type X with a proper vented box, you'll love it. If you do decide to go with a pair of 8's you should check out these:
http://www.soundsplinter.com/rli8_su...formation.html
A pair of those on 1000 watts in vented enclosures should outdo a 12in Type X all around plus you get the bragging rights of having 8's that get stupid loud.
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
backtothe80s
Sep 5, 2015 12:39 AM
Street Lethal
Aug 13, 2015 08:28 PM
marcusaw
Aug 10, 2015 08:13 AM
