Confused
Old Mar 3, 2013 | 09:18 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
Confused
I am looking to put 2 12in subs in my cargo area, as well as 3 amps, but, I am also installing a 10lb nitrous bottle with a bottle heater in there as well. I am trying to come up with a box or enclosure of some type that will allow for as much room as possible to do this. Any suggestions? I know I will need room to get to the bottle brackets in order to pull the bottle for refills and such.
Old Mar 3, 2013 | 10:10 PM
cdoyle's Avatar
Re: Confused
What type of subs and amps? Why 3 amps?
If you don't care about having a spare, you could mount your amps where the spare tire would normally go. Just need to make sure everything stays dry in there.
Old Mar 4, 2013 | 01:01 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Confused
The first two options I think of are:
1: Mount N2O tank in spare-tire area.
2: Use baffle-board instead of box and appropriate 12" drivers. Amps can go into glove-box area at driver-side rear.
Old Mar 4, 2013 | 10:36 AM
Dezined's Avatar
Car: 91 Camaro RS - B4C option
Engine: L98 5.7l V8
Transmission: 4 speed auto
Re: Confused
I'm thinking same thing. You can fit a 12" in the spare tire area that's removable (no fiberglass), I've done it and a fairly decent size amp will go in the drivers cubby back there. If you have free air subs, might just build a shelf with some hinges so you can open it at the top of the gas tank hump, and put the bottles and acc in the bottom of the cargo area there.
Old Mar 4, 2013 | 07:09 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Confused
My old set up was 3 amps and crossover mounted on a board (carpeted to match interior) on the rear diff/gas tank hump and 2 12s in a box in the well. i always wanted to either run a hidden nitrous system in the spare compartment or mount it right in the open on the drivetrain hump between the rear seats.
Old Mar 18, 2013 | 03:01 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
Re: Confused
I hadn't thought about the rear hump. That may look pretty good!!
Old Mar 20, 2013 | 08:58 PM
Car: 92 Camaro RS
Re: Confused
If you do, please post a pic.
Old Mar 21, 2013 | 07:55 AM
Rickey_85TA's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305 (5.0L) TPI
Axle/Gears: 9 Bolt Borg Warner Posi-traction
Re: Confused
At one point I had two 12"s in a custom made box on top of the hump right behind the back seats. I will try to take some pics when I get home. I still have the box if anyone is interested.
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
