BASS...
Old Sep 11, 2000 | 03:35 PM
Keithz's Avatar
BASS...
hey, i want to get the rockford HX2s. they sound pretty good in my friends acura, but i have an 84 camaro and its gonna sound different.
i want three 12s in a sealed box so i dont have to switch the box i have now. will this settup be loud? what kind of spl's would i probably pull off of this settup? (they will get 500 watts rms each, i have the amp all hooked up, but not running any subs yet)
Old Sep 11, 2000 | 05:00 PM
SCOTTCAMARO1's Avatar
hey man i have 2 of the old style punch 12's in my 92 with a ppi pc275 pushing them im hitting 141.4BD so with 3 12's and the right amp you should have no problem shattering that back glass
Old Sep 11, 2000 | 05:01 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Depending on your amp, that setup has the potential to hammer. I'd say 145-148dB would be possible with proper tuning and with a good amp.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 11, 2000 | 06:11 PM
Keithz's Avatar
i used to have three 12s of the older punch dvcs and it rocked. then i had one stolen and i couldnt replace it cause i couldnt find anyone that had them in stock. so i decided to sell the other two and get a new sub system. (they stole one cause the other 2 were installed with torx screws )
i have a rockford power serries amp, i forget which one, running mono.
(any one out there know how to stop a theif from breiking the rear hatch lock!!??!!??)
Old Apr 28, 2007 | 05:29 PM
fdhagesrty4gu8's Avatar
Car: I don't.
Engine: I will have.
Transmission: TBD.
Axle/Gears: None.
Re: BASS...
Bass is Baaaad.
Old Apr 28, 2007 | 06:28 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Re: BASS...
Not possible
If they want your system they'll put a brick through the back glass, best defense is not to show it off too much and don't leave it in a seedy neighborhood.
Old Apr 28, 2007 | 06:57 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
Re: BASS...
jeezus , this post died in 2000 the necro's brang it back!
and RF's suck simple as that =) there amos are decent subs suck not worth the month can get better sounded amps for there prices for SQ SQL or SLP
Old Apr 28, 2007 | 11:36 PM
stew_pidaso59's Avatar
Re: BASS...
its back up and running, i use a punch 200 with three mtx subs in a sealed box and it hits HARD
Old Apr 30, 2007 | 10:01 AM
Jim85IROC's Avatar
Re: BASS...
Those HX2s hammered for their time. Their amps were also powerhouses back then too. Back then class D stuff was just starting to show up from premium manufacturers, and weren't cheap yet.
Old Jan 8, 2009 | 08:10 PM
lil tp1983's Avatar
Car: 92 RS
Transmission: TH400
Axle/Gears: 2:73
Re: BASS...
I want 3 12's in my 92 rs does anybody have pics of their camaro with3 12's
Old Jan 8, 2009 | 10:32 PM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
Re: BASS...
if ur going Mainly for SPL id go with some 15s more power always better IMO but i think 145 db is a really high estimate these cars can get loud easy with it being a hatch but 145 is LOUD
Old Feb 16, 2009 | 12:16 PM
sexxxywesley's Avatar
Car: 1989 Camaro RS
Engine: 355 lt1
Transmission: 700R4 stage 2
Axle/Gears: 3.73 gears and a 9 bolt borg warner
Re: BASS...
yeahh the diffrence is the hatch adds 3decibles than other cars with a trunk but it sounds like a pretty good set up
Old Feb 16, 2009 | 08:30 PM
NewJerseyMI's Avatar
Car: 91 RS (In project) 350 TBI
Engine: 350 TBI Pulled From 87 Chev Truck
Transmission: stock Manual 5 speed
Axle/Gears: stock
Re: BASS...
LOL, on a 1500 watt rms system sealed. You obviously have know clue about car audio or know how much it takes to shatter glass with a sub.
It will be loud thoe, but not that loud to shatter glass lol. It will be more towards sq than spl cause of the sealed box. Are they 4 0hm or 2? How are you wiring them and what amp are you going to push them with?
If you want to get down to the bottom of it come over to where i go for any audio questions at ecoustics.com and post your question on the car audio subs forum there. Theyll hook you up and know there sh.it when it comes to car audio.
86irocIrock
Car Audio
Mar 7, 2015 07:50 AM
83 Crossfire TA
Car Audio
31
May 14, 2013 06:27 AM
Steve89GTA
Car Audio
Feb 3, 2003 02:42 PM
Xenodrgn
Car Audio
Aug 14, 2002 02:22 PM
