HOME MADE AMP, like alot of watts!
Old Dec 27, 2001 | 09:11 PM
un4givin89's Avatar
I been working on wiring this up I'm almost ready, tell me if you think this is sound? Or if I'm just stupid. I'm running wires from the alternator to all of my speakers! Just like you would an amp. You know ins and outs with alil power boost, get what I'm talking bout? I'll draw a wiring digram. BRB
Old Dec 27, 2001 | 09:16 PM
XxMoLexX's Avatar
sounds interesting... but i dont know ... im sure if it were safe and possible.. it wood have been done... but im not an electrician by any means....
Old Dec 27, 2001 | 09:27 PM
jobryan26's Avatar
Man,..... what have you been smoking? I don't have a clue as to what you're doing, but as long as you do i guess that's all that matters Good luck and keep a Fire Extinguisher near bye!
Old Dec 27, 2001 | 10:10 PM
BAK12484's Avatar
how in the heck do you plan on getting the signal from your headunit to your speakers?? An amp doesnt just supply power to the speakers, but it also routes signal......
lemme see the diagram then i'll decide how crazy you really are
Old Dec 27, 2001 | 10:37 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
This is why some people shouldn't be allowed to be left alone with tools.
Old Dec 27, 2001 | 10:51 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
amp
i hope you dont have too much money in your head unit or speakers. lol, i wanna see this odd idea of yours, post a diagram of your plan, goodluck
Old Dec 27, 2001 | 10:52 PM
un4givin89's Avatar
me like power tools, mike the tool man
Old Dec 28, 2001 | 05:24 AM
gmanuel's Avatar
If you connect the postive power from the battery to the postive terminal in the speaker the speaker will either be pushed out or drawn in. This means that the amp will have to have more power then the battery to return the cone to the normal postion and then even more power to cause the cone to be drawn into the speaker enclosure. are you sure that the amp can handle 12 volts D.C. at the speaker terminals? also you are going to drain your battery and short out your alternator because you will be shorting them to ground though the speakers. You will have any from 2 ohms to 8 ohms resistance. Make sure you get your little brother to make the last connection
Old Dec 28, 2001 | 11:33 AM
un4givin89's Avatar
i was just gonna run one wire to the pos side of the speaker and another wire to ground.
Old Dec 28, 2001 | 11:48 AM
Drew's Avatar
Originally posted by un4givin89
pos
Got at least part of that right.
running power and ground to a speaker will do wonders... *sarcasm* Try it and let us know how it goes.
Old Dec 28, 2001 | 12:28 PM
un4givin89's Avatar
it melted
Old Dec 28, 2001 | 02:41 PM
DJSexay's Avatar
hmm, let's just theorize that this would work, forget the fact that speakers need AC, and let's pretend that they need DC.
We have a 4ohm speaker.
We have 14 volts of electricity.
So we have 3.5 amps of current. (V=IR)
Now, we take the 3.5 amps of current, times the 14 volts.
We have 49 watts (P=IV)
Not that impressive. Now, let's take a 1 ohm DVD Sub
1 ohm, 14 volts, we are left with 14 amps (V=IR).
For Power, we now have 196 watts. Hmm, still not a whole lot.
Ohwell, at watching the cone on the speaker push out from the DC current was cool
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyle5647
Aug 15, 2015 11:56 PM
