Original 4x6?
Re: Original 4x6?
they look original-8832 date code is 32nd week of 1988, these are usually 10 ohm,sometimes 4 ohm.
Car: 90 Formula / T-tops
Transmission: MD8
Re: Original 4x6?
I've seen Japan around here. My1990 factories were from Singapore and say Delco Electronics. https://www.thirdgen.org/forums/elec...ml#post6330536
mantaguy (05-02-2024)
Re: Original 4x6?
Ok, 10 ohm.
Here are the rear 6x9. Again I assume original and obviously 10 ohm.
Here is the original radio (as far as I know)
I had M&R rebuild it and add the aux cable.
Looking through Crutchfield catalog, I only see 4ohm replacements. What do you guys think about using 4 ohm instead of 10?
Re: Original 4x6?
Don't do it: ( watch the video )
https://www.thirdgen.org/forums/car-...ml#post6336618
Edit: Factory head unit can power 1 4-OHM and 1 10-OHM on each channel (L-or-R). Some/Most Pontiacs used 4 OHM rear 6x9's. Connecting 2 4-OHM speakers to 1 side (L or R) side is not advised.
Re: Original 4x6?
I understand why the link doesn't work by simply clicking it; Site doesn't seem to want to redirect to an 'outside' website ? It used to work by just clicking the link, but not anymore. However: If you cut/paste the web into your browser,... you can watch it.
http://berlinetta.info/video/4OHM.mov
KCG (05-08-2024)
badblackbelt
08-28-2016 12:41 AM
