Car dies after burnout ....
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The setup is a Holley 750 Vac sec on a performer rpm. External Holley blue pump with KN filter. Last year it started dieing sometimes after the burnout. Still happenes now, but seems to be getting worse. Runs great during the run though, so it doesn't seem like the fuel pump since it uses a lot more fuel during the run than during the burnout. It's ran great for 2 years prior, then this started happening. Any ideas?
Miles
Miles
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
i think it means u have a vacuum leak. it does that to me too, but cant find a leak. i dont know if thats it cause im pulling 16 inches at 700 rpm
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If you wouldn't mind, describe your burn-out routine and what happens before, during & after, in a little more detail. Also what fuel pump you're using.
This is going to be a rater odd response to your question but hear me out.....
It COULD be your ignition. I JUST went through something similar with my friend's car/engine. After 2 YEARS of gradually getting worse we FINALLY nailed it. The ignition coil got flaky. It would pull like a mule running through the gears. As soon as you let off the throttle and let it coast down it would DIE. It used to just kinda stumble around for a while and then clear up. But if got worse over time, eventually leaving us stranded by the side of the road for several minutes before it would restart after every WOT run. It occasionally seemed a little weak in the upper RPMs but no popping of hesitating like you would normally associate with a "dead" coil.
Something in the coil went wacky any time the coil would heat up. Let it cool down and it would run fine.
I am NOT saying that this is definitely your problem. But we chased carb issues out the wazoo before we started looking at the ignition. And that car uses basically the same HEI distributor/coil that your car uses. Coils die sometimes. And sometimes in very odd ways.
A vacuum leak is another definite possibility, as CR125 says. In fact, I'd check that first. Just wanted to let you know of this "odd" ignition behavior in case some of the symptoms line up with yours.
Remember- 90% of all carburetor problems can be found in the ignition!
Yes. I did a new cap at the same time. That made it an easy swap. Assemble the new coil into the new cap and then swap the whole assembly with your old coil/cap as a unit. Saves for from the possibility of dropping/losing any small parts trying to do it leaning over the fender of the car one piece at a time. Still gotta swap the coil cover over separately but that's easy.
The only other part that I'd consider swapping that could cause similar problems would be the ignition module. Usually, though, they either work perfectly or not at all.
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
R-U running an atomatic trans with stock converter? Sudden off throttle with tires that are hooking up will pull the rpm's down to 0 and kill the motor not to mention wear and tear on the conv. might try easing off the throttle instead of jumping off it suddenly. Just a thought! If your running a man. trans, don't pay any att. to this!
db057
08-11-2015 10:11 PM
novaderrik
08-10-2015 12:44 PM
