What is the RIGHT carborator?
Its time to put a new carborator on my 83 305 v8 trans am. when looking for a new carbaortor i found out its not as simple as just saying GM v8. they have all sorts of diffenernt displacement values and such.
Im in California so i cant go nuts with it really. I just want to put a basic, nothing fancy carb on it so i can get the best fuel mileage possible out of it.
What are the stock or correct numbers to look for when searching for a carborator?
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
what is wrong with the carb you have now? i would rebuild it because i know california is smog heaven but are strict on the laws about emissions. i would stick with what you have and put a rebuild kit in it.
I already rebuilt it and cleaned it thoughly. after the rebuild i took the car in to have the carb adjusted. I was then told that there is something internally wrong with the carborator and a kit would not fix the problem. The only way that carborator will be fixed is though a complete rebuild. the kind that companies like Holly do.
James
James
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Unless you have a Canadian T/A, it's probably a good idea just to buy a rebuilt CC Q-jet.
As five7kid frequently points out on this board, it's more trouble and money to switch everything to non-CC than it is just to use the stock CC Q-jet. Not to mention the stock carb flows more than enough air for a 305.
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Well the rebuilt CC QJets are not cheap, but it would be a surefire way to get a carb that works if you want to stay with a Computer QJet.
Use the carb setup you want to use on your car, not the carb other people try to convince you to use. It's not that much trouble to switch to non-computer controlled carburation.
Car: 4
Engine: 6
Transmission: 5
You can't switch to a non-computerized carb. You're in an "enhanced" emissions area in California. They'll not only check to be sure that every wire and hose is hooked up to it in its factory location, they'll even check the part # on your carb. It will need to be one on a very short list in order to pass.
Fix what you've got, or replace it with an identical one. Those are you only choices.
There is no cuttoff on car year in California? In most states once a car reaches a certain age it is exempt. When Florida had emissions they did it that way. Don't know about California.
Engine: 4 cylinder
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
i was browsing through the jegs catolog and they offer remanufactured Q jets. if you cant rebuild what you have, id buy another Q jet. i lived in california and its no joke out there
1 Old Timer
Dec 18, 2002 08:39 PM
