q-jet problem with wiring
Old Jun 30, 2004 | 02:50 AM
84 firechicken's Avatar
Car: 84 firebird
Engine: 305 h/o
Transmission: auto for now
my car started life with a 4-cyl now its 305 and the q-jet has electric fuel rich and lean and i dont know what i can do to get the car to run right cause the computer has been removed and the car has been reconfigured to not use it and every time i start it it puffs smoke and is runnin way to rich
Old Jun 30, 2004 | 09:45 AM
ljnowell's Avatar
if the computer has been removed, and the CC Qjet is still on there, then it hasnt been reconfigured for anything. YOu need to either install a computer and the all of the wiring, or get a non CC distributor and carb and use it. You cant magically un-computer control the CC QJet
Old Jun 30, 2004 | 10:25 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
As LJ was getting at, is the carb the original CC-qjet? Incidentally, computer controlled carbs need a computer to function. There are, however, non-cc versions. Some date to pre computer era. The canadian version also got non-cc i believe.
Old Jun 30, 2004 | 10:43 AM
HamsterOnaMission's Avatar
I have a similar problem.
I have a destroyed (rodent chewed) harness for a cc set up, however, the dist is vaccum advance, and there is only one conection to the carb (top facing passenger side), for two wires that i can't find.
I have a cc q-jet and cc dist as well, but they're in bad shape.
I believe i'm also running rich. Any suggestions?
If anyone has a wiring diagram of what the cc harness should look like (I can't even piuece it back together, missing sections, previous owner tried splicing, etc) I guess i could rebuild the other carb and put the other dist in.
Thanks.
Old Jun 30, 2004 | 10:53 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: q-jet problem with wiring
Originally posted by 84 firechicken
... the q-jet has electric fuel rich and lean...
That sound a lot like the electric choke adjustment. That exists on all q-jets with the choke on the carb itself. Almost all of the later q-jets (late-70's on) were of the electric choke variety. The "hot air" type of choke also have the rich<->lean adjustment. But, this only adjusts the choke, not the carb's other functions.
... i dont know what i can do to get the car to run right ... every time i start it it puffs smoke and is runnin way to rich
Is the problem during start-up and cold running only, or all the time?
Really need to know if this is a CC q-jet or not. The CC version has 3 electrical connections (choke, upper-passenger-side corner, and middle driver's side corner). Non-CC will have a connector on the choke, and some have one on the upper-passenger-side corner as well (Canadian and some US truck versions).
Old Jun 30, 2004 | 11:02 AM
Non CC???
Note white connector on top of carb
Old Jun 30, 2004 | 11:03 AM
What I Have
Dirty and needs a rebuild
Old Jun 30, 2004 | 11:05 AM
Wiring disaster
Any diagrams you guys have would help
Old Jun 30, 2004 | 11:21 AM
five7kid's Avatar
The top picture is of a non-CC q-jet with the 2-stage accelerator pump connector. The distributor is also non-CC, with the vacuum can on the distributor base. (Nice even coat of corrosion on everything, by the way.)
The 2nd picture is of a CC q-jet and distributor. Note the 3 connectors, and the distributor doesn't have the vacuum can or mechanical advance weights. 84 firechicken, if your carb and/or distributor look like this picture, you've got some changes to make.
The 3rd picture is what happens when people tear into things they don't understand . The Haynes manual has wiring diagrams in the back, all you really need for non-CC is switched power to the Batt terminal on the distributor, and a separate switched 12v power to the electric choke. The two-stage accelerator pump is optional, but is operated by a coolant thermal switch in the thermostat housing. IIRC, it needs power to operate the larger shot for cold operation, but I may have that backwards.
Old Jun 30, 2004 | 11:23 AM
is the two stage accelerator pump the white connector? i was unbder the impression that controlled the mix
Old Jun 30, 2004 | 12:04 PM
five7kid's Avatar
Yes, accelerator pump only. The mixture ratio is controlled via internal vacuum/mechanical mechanisms.
The blue connector goes to the mixture control solenoid in a CC carb.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bert87
Aug 23, 2015 03:50 PM
Fronzizzle
Aug 17, 2015 02:52 PM
