Need to tone it down! (V6 Carb)
Car: 1987 Z28
Engine: Tree Fiddy (modded)
So In my other thread in the V6 board, I was wondering how I can get better gass milage. Right now I get 9.81MPG on my v6
pretty good eh? no, didnt think so.
So i was sent here to ask, how do i tone own the ammount of fuel my carb is letting in? Im running so so so rich.
thanx
pretty good eh? no, didnt think so.So i was sent here to ask, how do i tone own the ammount of fuel my carb is letting in? Im running so so so rich.
thanx
Car: 1986 Trans Am
Engine: LG4 305 (The wheel's still spinnin but the mouse is dead!)
Transmission: A4 Automatic (Little Rusty Wheel) heh
im not a carb educated person, but I think you need to rebuild it, sounds like the float is stuck and just kinda POURS the gas in, you may want to replace the sparkplugs and let the engine dry out of excess fuel from the plug holes by leaving them out while rebuilding the carb. I also suggest changing the oil as it may be fuel saturated.
Car: 1987 Z28
Originally posted by 86TA305Ga
im not a carb educated person...
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
you can awalys buy a new 2 bbl holly shouldnt be more then like 300 but i would first figure out how to tune yours as im sure its somethin simple.
Car: 1983 G20 Chevy
Transmission: 4L60
Sounds like you need to buy a book on Rochester carbs as well as make sure your choke is opening!!! Also as mentioned it very well could be your float is fuel saturated therefore no longer floats correctly or at all.
Car: 1987 Z28
The choke is alright, I checked that after a long drive. But yeah, I should goto the junkyard and buy a carb and try rebuilding that one. sheesh
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
Try leaning out the mixture? Mine was guzzling gas too til I found out it was basically flooding lol. Leaned out the mixture with almost 8 full turns and now it sips gas without any adverse effects.
Car: 1987 Z28
Filled up sunday, drove to school today, and back, now im down to 3/4 of a tank in a 35KM total drive
thanks alot
Oh yeah, if you cant take a pic is there anyway you can pinpoint to me where it is? Or if i take pictures of the carb?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
back, passenger side. look for a "nipple" going back towards the firewall. it should be a hollow tube, in it is what looks like a fat flat blade screwdriver. use pliers to turn it.
"tighten" = lean
"loosen" = richer
hook up a vacuum gauge and set for max vacuum....
at the same time, note your vacuum, post it. then you'll know if you have a vacuum leak or something is funky...
"tighten" = lean
"loosen" = richer
Car: 1987 Z28
wow, thanks so much, I will have a look tommorow when I can see. i really hope this helps
If this fixes it i can get my 80 bucks back from the carb rebuild kit
EDIT: Sonix, is that the Idle screw your talking about? or some other mixture screw? Cause my idle is fine. Just wondering. Thanx
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
$80 for a rebuilt kit? Are you sure you didn't buy a trick kit? Rebuilding a carb is not as hard as you may think. If you run into any problems the TGO guys give great advice.
Car: 1987 Z28
Yea I hope it isnt to hard, Ive tried a 4bbl in school in my mechanics class and it went ok.
And if anything EVER goes wrong with my car the first place I come is to TGO
Helped me so much in the past Member
Engine: 355 TPI
at the same time, note your vacuum, post it. then you'll know if you have a vacuum leak or something is funky... [/B]
Car: 1987 Z28
ThUnDeR2005 - where did you find that screw you turned? sonix gave me an idea but i heard 82 carbs were different then 83 carbs.
please help
if not im going to PM you to death
lol
please help
lol Member
Engine: 355 TPI
We adjusted mine in front of the carb facing the nose of the car. Needed a special adjustment tool (its like a wobbly screwdriver) and just found the right fitting and turned the screw. There should be some sort of hollow tunnel shaped thing in the front on the bottom of the carb. In there is the screw to adjust with
When you adjust it turn the scre in until you hear the car start to stumble then back out out about half a turn and your good to go.
Engine: 355 TPI
its under the air cleaner, you'll hafta do a little looking. Maybe if I get some time here, I'll post it up. I just purchased a 79 camaro that HAULS and im having fun with that.
Engine: 355 TPI
It is FAST RS, dead center facing the nose of the car on the front.
And no problem, 83_Camaro_83. For all the help I received here, might as well give some of it back
Car: 1982 Trans-Am
the 4bbl idle mixture screws (two) are on the front. based on the picture I sent you, it (single) is on the back passenger side... but yea, that's '82.... and who really knows... you can buy a tool to adjust it for $20 at Napa, or $5 at princess auto (last I checked..) or use needle nose pliers if you're careful. the screw is capped by the factory however. if the carb has never been rebuilt, you will NOT be able to get at it. you have to cut/grind/file/drill to get at it. so if you can find it, great, adjust it, otherwise, get ready to rebuild. (but yea, i'd pick up a junkyard one to rebuild, in case you screw it up you can always put your factory one back on, at least the car will run...) plus you'll get a (most likely) good float on the junk one.
$50 rebuild kit and $25 float? you got ripped off. hope you kept the receipts. get another carb from the Pick-a-part and use the extra pieces. you'll need the kit for gaskets etc, but the float should be fine in your carb (those are pretty tough to get to fail...) and if you get a junkyard carb for $14 you'll get a float that most likely will work..
but yea, adjust your mixture. you can do it by ear (until it stumbles, then back a bit), or with a vacuum gauge if you have it.
vacuum gauge is in inches of mercury. not psi. you should get over 15 with stock cam etc.... I can only get 15" but I think I have a vacuum leak, extremly hard to start the car etc.... 17"-22" was what someone told me in my previous thread...
-J
-J
ambainb
Apr 25, 2016 09:21 PM
Philly89Iroc
Oct 1, 2010 12:22 PM
