HELP HURRY HURRY
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
HELP HURRY HURRY
ok so my alternator and smog pump went out and i just replaced them today...i started it up after i got alternator on and it ran then i installed smog pump and stuck the battery on charge sence it died...when to go start it and im getting a clicking noise coming from the carb i think its a fuel sensor or reglator cuz it wont start its like its not gettin any fuel...i can have the key on the on spot and the clicking will go for about a min.. i found the plug that is causing the noise its on the front of the carb like a blue plug sticking out with a black clip that goes into it...its the stock 4barrel carb...i have no clue what to do what to look for what it might be...i checked all the fuses they are good...i looked for hoses disconnected didnt see any...and all the wires look fine...dosnt make sense worked fine like an hour before...then it just stops...anybody got a clue what it is and how to fix it....
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Are you sure the clicking isn't your starter? Thats what usually makes that noise when you try to start it and it wont fire over.
Engine: 350sbc
100% positive its coming from the carb...cuz i unplugged the connector on front of carb and it turns off plug it back in and it turns back on...car is acting as if it has no fuel...
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
My car was making that clicking noise too. So I thought it was the starter, but instead I charged the battery and it started up. The computer in third gen's don't work to well if you have a dead battery. Try charging your battery.
Transmission: 4L80E/4L80E
Engine: 350sbc
problem fixed...was a combination of battery wasnt fully charged even though charger stated it was and it had a enough power to turn over the starter but not get it all the way on...and belt wasnt tight enough on alternator...thx for help guys...
Mikes86SC
Jun 10, 2002 11:41 AM
firebird305
May 24, 2002 08:20 AM
redbird_400
Jan 28, 2002 09:05 PM
