Best carb for daily driving?
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Besides a q-jet what carb is the best for performance reliability and economy? i'm looking for somthing I can go buy brand new.
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Best carb for daily driving?
youll get a lot of responses on this, IMHO Edelbrocks are great for daily driving, and they are the least expsensive carb...I have a holleys street avenger on my IROC, its great i dont daily drive it but i use to dd my 86 with a street avenger and never had a problems...
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
It's all a matter of opinion. holley guys will be holley guys, qjet guys will be gjet guys edelbrock guys will be edelbrock guys. If u want to just bolt on and go, edelbrock's are pretty easy. If u want performance go holley.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
get a double pumper and check out the sticky on holley tuning.
I love mine.
I love mine.
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Cheap and economical... I'd say Edelbrock 1406, 600 CFM. It'll do fine for any stock motor from a 3rd gen... or a slightly modded 305. You might sacrifice a couple HP on top because of the smaller size, but below about 6000 RPM it's probably negligeable. They also run very well straight out of the box.
Car: 1987 Firebird
Engine: 355
You will never beat the q-jet for that in my opinion. Can be rebuilt in about 20 mins, for about $60. They are a dime a dozen, easy to tune. Just get one from the 70s. The ones that came on our cars, give the q-jet a bad name.
Whatever you chooze, it should have an electric choke. But i think an edelbrock 650cfm is your best bet if not the q-jet.
Car: 1991 Z28 1LE
Transmission: 4l60e
you have a street car with an automatic so dont get a double pumper stick with vacum secondaries
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Performance, reliability, and economy - the exact description of the computer controlled q-jet.
New carbs:
Cheap - the best description of a Performer.
Getting less than you pay for - the perfect description of the Street Avenger series.
Inappropriate for a performance car - the general description of a vacuum secondary carb.
Automatic transmission is absolutely not a disqualifier for a double pumper carb. It's the prevailing attitude of "bigger is better" that has made manufacturers shy about recommending them for auto cars. The issue isn't the double pumper not mixing with auto trannies, it's the minimum RPMs you go WOT - and the Holley site has a chart to show you how to size properly. On a 350, you can put a 750 DP as long as you have at least 1500 RPM stall - no reason whatsoever wasting your performance $'s on a VS carb.
If you really, really want to downgrade from the stock CC carb, and absolutely have to have a new carb, consider the Holley 6210 - spreadbore type, double pumper, 650 CFM. Electric choke will be one difficulty with it.
New carbs:
86IROC112
08-17-2015 02:00 PM
