carb troubles
Old Apr 6, 2001 | 11:26 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
carb troubles
I've got an edelbrock 750 4bbl carb
#1407 which is acting up on me. The car surges and misses throughout the rpm range, if there is a load on the engine it will backfire. I swapped carbs to my old carter AFB and the problem dissapears.
I checked primary and secondary jets, blew air threw everything, but that didn't do anything, i checked floats to see if gas leaked into them,
has anyone encountered a problem like this? it almost seems like an ignition miss, however all ignition components have been replaced, thats how i figured out it was a carb prob
what could be causing my backfire, missing and rough idle? any ideas?
Old Apr 9, 2001 | 12:58 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
anyone??? even edlebrock does know wtf is up
Old Apr 9, 2001 | 03:54 PM
82camaro's Avatar
Car: 82 camaro SC
It's lean. Could be a bad vacuum leak. If it was a Holley I could help more.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 11, 2001 | 12:26 PM
Damon's Avatar
I agree it's probably running lean. THere should be no smoke coming out the 'pipes while this is happening. If you're getting clouds of black smoke out the back it's too rich. But it sounds like typical lean symptoms to me.
What could be causing it? About a dozen different things. Metering block gaskets could be bad, installed correctly or misaligned. Could be there's dirt wedged in places the compressed air couldn't blow it out of. Etc., Etc. Maybe if we had a little more info about the exact circumstances surrounding the problem. The more info the better. No detail is unimportant.
Old Apr 12, 2001 | 05:20 PM
The ODB's Avatar
an Edlebrock #1407 does not have a metering block/gasket.
Sounds like you didn't get "everything" cleaned out.
Old Apr 13, 2001 | 02:06 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My #1406 does the same thing.
It's driving me crazy.
Runs ok for a while, then starts to run like crap.
If it starts to bog and backfire and I go WOT it doens't bog or backfire. As soon as I let up and accelerate easily it will start to bog and backfire.
It seems to happen when the motor gets warm.
The gauge reads 160-180 on the cluster, but the engine bay seems very hot.
I also have an open element air cleaner. Could all that hot air be causing the car to run like it does?
I can't wait till I can afford to get a TPI setup for my car, maybe then all my headaches will go away.
When the car runs like crap, it makes me not want to drive it anymore, I just get all frustrated.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph
WS6 Trans Am.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
WS6 Trans Am
Old Apr 13, 2001 | 04:35 PM
The ODB's Avatar
Zepher,
you will get a great deal more headaches with tpi.
Why not just find what's wrong with your carb and fix it? chances is are it just has to do with you maybe not keeping the air or fuel as clean as it needs to be to prevent clogging of the carb passages like the air-bleeds. It only takes about 15 minutes to remove and disassemble the carb and clean out everything.
good luck,
ODB
Old Apr 13, 2001 | 04:41 PM
Zepher's Avatar
I'll try and tear her apart and clean her up and see if that fixes the problem.
I just want to get TPI for the fuel economy right now, since gas is up to $1.59 for 87 and $1.74 for 93.
Old Apr 14, 2001 | 12:41 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Try a Holley . You will be glad you did.
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression 186 casting Heads,234dur.488lift exh&int,Edelbrock performer intake, Holley750 vac.sec 400 crank,flat top pistons,edelbrock valve springs and lifters,tranny shift kit,2500 stall converter. Will install 3.73's later on and might go with a more aggresive cam.As of 4/01 added Hooker Headers,2.5inchpipes with 40 s. Flowmasters.Ignition upgrade include: MSD Coil and MSD module.
[This message has been edited by Big454blockchevy (edited April 13, 2001).]
Old Apr 14, 2001 | 02:41 PM
Bad406Rs's Avatar
I would recommend selling it and buying a Holley. I bought a Edelbrock and bolted it on right out of the box and it was horrible. It ran so bad I sold it and went to a Holley. When I figured out what was wrong I was amazed. The Fuel bowl levels were way off from one another and the bowl drop was off. This should have been set correct straight from factory. Sell it or junk it and buy new, you will never be disappointed.
Old Apr 24, 2001 | 12:05 AM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
same here, i pretty much gave the edelbrock away. i stand behind holley carbs 100%. edelbrock intakes are great but i couldnt get the carb to perform like a holley.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
Old Apr 30, 2001 | 04:57 PM
The ODB's Avatar
I suggest you guys all sell your Edlebrock carbs to me really cheap. Even though it's usually only dirty airbleeds that cause the problems, you really don't want those low-performance Edlebrock carbs.
If anybody wants to sell theirs just shoot me an email and we can negotiate.
thanks..
ODB
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305 with iron #416 heads,
383 with aluminum TFS heads,
Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, Vigilante 2400 lockup converter, 3.25:1 Ford 9" rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, sometimes advertised at 216/219 @.050 112-LSA .462/.470 lift @1.5:1 ratio. Using Harland Sharp 1.65:1 roller rockers. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch. SouthSide machine subframe connectors, SSM lift-bars, Moroso 4" underdrive crank pulley.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
* vizit miy homepayge * http://www.geocities.com/trailerparkpage/
Old Apr 30, 2001 | 08:25 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
I like the edelbrock carbs too. They are not complex and are eas to take apart and tune. IMO
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
Old Apr 30, 2001 | 11:11 PM
Slow83Z28Camaro's Avatar
worst thing bout holly is the choke
Old May 1, 2001 | 12:13 AM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
hehe ODB if I get my Demon carb any time soon I'll sell ya my edelbrock its a 1407 too
but it dun have their problems, its perfectly fine... I just don't want it cause a Demon is better than both edelbrock or holley and I like the removable venturi's
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
sreZ28
Oct 22, 2015 08:21 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
