4 barrel carb on a v6....
Car: 82 camaro SC
If that is all you did, it would be a waste. If your v6 can't benefit from the additional air flow a 4 barrel carb will provide it won't help--it may even hurt. If you have a modified v6 that revs really high and can benefit from the added air flow, then sure it will help.
It's all about the combination, not one or two parts of the combination.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Car: 1983 Z28
Engine: 6.6L 406
no just buy the carb and then put a 350 in then put the carb on.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
future mods:
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I actually looked back into this, way back when I still had a 2.8. Why?
Well, my 2bbl carb was SHOT, and for some reason (availability?) a rebuilt 2bbl carb cost about DOUBLE that of an E4ME qjet.
If you could get a 4bbl intake for a 60 deg V6 (2.8/3.1/3.4), you could make it work. Just be careful about which vacuum lines go where, and you'll have to come up with a way to bypass the EFE heated grid. Wouldn't be too bad actually.
Now, whether or not the secondaries would ACTUALLY open is another question entirely
. I'll make a deal with you guys!
If you can find a 4bb manifold for a 2.8, 3.1 or 3.4 I'll buy it and rip my FI out of my blazer in 5 minutes and give you all the info you would ever need on swap and setup.
SSC
SSC
<font face="Verdana, Arial" size="2">Originally posted by SUPER-SPORT-CHEVY:
SSC </font>
SSC </font>
Car: 3
Engine: inboard
Transmission: underfloor
I believe Edelbrock makes a 60 degree (2.8/3.1/3.4) four barrel intake and a 390 cfm Holley would work. Try going to s-series.org and get on the v6 message board, I know there's a few 3.4 Camaro swappers into former 2.8 trucks using a four barrel on there.
SSC
SSC
Re: 4 barrel carb on my 3.1 92 marro
Car: 86 TA, 00 Z28
Engine: L31 Build in Progress
Transmission: NWC T5 till it blows
It will have **** loads mor torq but i get a 3.1 in mine couldnt figureout probs so.i edlebrokex the hole.top. end on ma 3.1 92 camarrow i got a high rise toker 3 and a 850 cfm 4 barrle holly and fulle presure regulater go whatch my tick tok vids on it blazeinjake420
what?
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: 4 barrel carb on a v6....
This thread is almost old enough to order whiskey at the bar.
It was ridiculous enough to begin with; but now, it deserves a n00b to come in a necro-resurrect it by posting something asinine and incoherent.
It was ridiculous enough to begin with; but now, it deserves a n00b to come in a necro-resurrect it by posting something asinine and incoherent.Thread
