Trunk Leaking
Trunk Leaking
Can't seem to find where the water is getting in. It filles up the bottom of the trunk but the carpet on the sides of the trunk are dry. I poured water around the trunk into the gutter and it drained porpoerly. Thinking back of car somewhere, maybe tailights. Ideas?
Re: Trunk Leaking
Check the drain lines that take the water from the edges of the trunk to the exterior. With the top down look down inside and you will see that there is a tube on each side of the car that takes the water from out side the trunk to take the water away. The tube sometimes comes away from where it is supposed to be fixed. And, make sure that the water has a clear pathway to underneath and away from the car.
Engine: 4++,350 & 305 CIs
Re: Trunk Leaking
Spoiler holes or the glass to decklid seal has failed. Remove the plastic trim one decklid and I'd bet you'll see water marks on it.
Re: Trunk Leaking
I didn't realize this was in the convertible forum... oops, sorry about that.
Car: 91 Trans Am convertible
Engine: LB9
Axle/Gears: G80/GU2
Re: Trunk Leaking
I'd be looking all around the tail lights and and the join in the trunk seal area, because if it gets in there somewhere it would run down behind the plastic trim panel unnoticed until it gathered in the trunk well.
Think about how water could get sucked in while your driving as well as just rain falling down.
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: Trunk Leaking
