at what speed do the fans turn off?
Old Jul 16, 2002 | 01:48 PM
breathment's Avatar
Do they fans cut off at highway speeds? It would make sense that they would. BUt at what speeds?
Old Jul 16, 2002 | 02:32 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
If I remember right, they cut off at 45 MPH... but don't quote me on that. I haven't looked at my PROM in awhile.
Old Jul 16, 2002 | 02:40 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
The fan does not turn off at a certain speed on the highway. It turns off at a certain temperature. The temp. it turns off at is determined by the fan sensor.
BTW. How does your poly trans mount feel like a broken rubber one?
Old Jul 16, 2002 | 02:46 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Ok, I looked it up. 'Fan 1 Disable Speed' on my AUJP bin is 35 MPH. It does also shut off at a coolant temp, but I'm too lazy to look through the code to see if the speed overrides the temp shutoff.
Old Jul 16, 2002 | 04:05 PM
breathment's Avatar
well at high RPMS it has a really bad vibration problem.. I know poly is supposed to transmit more vibration, but this is rediculous at 4000 + RPMS
Old Jul 16, 2002 | 09:27 PM
Z28DJP1987's Avatar
My left side fan turns off at 30 MPH, but I am using a 180 deg
themo and Fastchip stage 2 chip. The right side fan works with the A/C and engine temp. I have no over heating problems.
Old Jul 16, 2002 | 10:02 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
As long as the AC is on, the stock Single electric fan stays on all the time to cool the AC condensor.
Old Jul 17, 2002 | 09:20 AM
TA5LiterHO's Avatar
The poly tranny mount.
Breathment. It is not uncommon to have a vibration at certain rpm ranges. My Trans Am has a vibration at about 3500and my friends Formula has it about the same as yours. Sometimes the balancing weights on the drive shaft can come off or move and this causes vibrations. I have a brand new rubber tranny mount and mine still vibrates.
Old Jul 17, 2002 | 09:29 AM
TA5LiterHO's Avatar
In reguards to my previous message.
When I said that the fan turning off is not determined by vehicle speed, I was refering to cars no longer using the stock fan wiring.
Old Jul 17, 2002 | 09:26 PM
KlayBuRn's Avatar
I changed to a poly mount also, and i had some vibration on my old 92 RS 305 TBI, i gave it time, and it went away...
Old Jul 20, 2002 | 05:50 AM
SIMON HOLTBY's Avatar
Removeing that preloading spacer made the vibes better with my car. Also made some rubber washers for that center bolt. almost like stock now.
simon
Old Jul 20, 2002 | 11:17 AM
88txiroc's Avatar
Regarding the fans........
I (and Willie) installed LED's with my cooling fan switches that come on when the fan is on. My (primary) fan stays on even above 35 or 45 mph. This is no problem with our fans, because they are pullers. I have a manual turn on for my secondary fan, as well. My car does not get above 200* at idle or cruising.
RazorN8
Jan 7, 2022 11:44 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
novaderrik
Aug 10, 2015 12:44 PM
92projectcamaro
Aug 6, 2015 01:20 PM
