rad. tank leak help please
Old Jan 20, 2003 | 04:16 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
my radiator tank is leaking, its about 5" down from the radiator cap, going to put some alumaseal in today but is there any other way to patch this?
Old Jan 20, 2003 | 04:49 PM
breathment's Avatar
if it is leaking there, chances are that u might get another leak somewhere else pretty soon. there probably is alot of corrosion and fixing that one leak isn't gonna do u any good other being a short term fix. is it aluminum or copper?
Old Jan 20, 2003 | 08:22 PM
llvll4l2c91350's Avatar
Agreed. Don't take chances with your cooling system. Upgrade to aluminum if you don't have it already.
Old Jan 20, 2003 | 10:13 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Those side tanks are plastic and have a gasket to seal them with the rad core. The only way to patch it would be to remove the side tanks, install a new gasket, then crimp back on the side tanks. Or there may be a leak in the actual side tank itself. Best just to replace the whole unit.
Old Jan 22, 2003 | 08:59 PM
MdFormula350's Avatar
coolant started leaking from the sides of my factory one, so i didnt take a chance a bought a new radiator..
Old Jan 23, 2003 | 11:43 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
i was an idiot and i tried to find the leak. alumiseal worked for about an hour. im sorry man just get a new one i paid 119 at murrays.
Old Jan 23, 2003 | 03:15 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Re: rad. tank leak help please
No.You can try high temp epoxy but it's only good for a short time. The plastic gets a crack down from the cap(almost always the same place). I personally like the plastic side tanks, I think they allow for the pressure changes better than metal.
Old Jan 23, 2003 | 06:14 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I had a local rad shop install a new side tank after mine cracked; cost around $35 over six years ago.
Pete
gta892000
Aug 11, 2019 11:16 AM
Bohemian
Aug 15, 2017 05:11 PM
tommy z-28
Oct 6, 2015 10:58 PM
bubbaz28
Sep 18, 2015 02:09 PM
bamaboy0323
Sep 12, 2015 07:14 PM
