lt1 fans--installed on third gen radiator complete!!!!!
Old May 22, 2009 | 05:44 PM
one92rs's Avatar
Car: SOLD!!!!!
i have searched and see thaat some people have lt1 and ls1 fans in there car. i think most have put the radiator from that app in at the same time. i just aquired a set of lt1 fans from a freind. when i measured the lt1 radiator it was only 25 1/4 across the core. my radiator is 26 across. has anyone mounted the lt1 fans to there third gen radiator? if so how did you mount yours? i will take some pics to show how i did mine. just curious if anyone has done this.
Old May 23, 2009 | 03:44 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: lt1 fans--installed on third gen radiator
boy what a pita. made some brackets to hold it to the radiator. had to cut some off one of the fans to get it to fit next to the gearbox. then had to space the fan motor in to clear it. then trimmed the upper rad cover. other than that it turned out perfect. these also move a ton of air compared to my little factory single fan.
Old May 23, 2009 | 03:45 PM
one92rs's Avatar
Car: SOLD!!!!!
few more.
Old May 23, 2009 | 03:59 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: lt1 fans--installed on third gen radiator complete!!!!!
I think most just use the dual fans that came on the third gens. Makes life a whole lot easier.
Old May 23, 2009 | 06:33 PM
one92rs's Avatar
Car: SOLD!!!!!
im down with that. for the price there was no comparison. plus i like the fact that these have a shroud.
Old Aug 17, 2010 | 01:33 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
What did u cut exactly to clear the gear box? I got a set of 97 fans, but I may just use a fourthgen radiator when I do the fans.
Old Aug 17, 2010 | 01:38 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Looks good man, its been a mod ive been debating...
factory dual fans are terrible, why gm never used a shroud is beyond me!
Luckily, my formula runs 180 in damn near any outside temp! so ive been kinda putting it off, i may do it if i have any heat issues with my new turbo setup
Old Aug 17, 2010 | 11:37 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
dual fans is prolly the easiest mod i ever did. someday ill have all my stuff out and ill take pics.
Old Oct 14, 2010 | 10:56 AM
thegooseman's Avatar
Car: 1992 RS
The fan that is controlled by the computer froze up on me so now I only have one fan. When I was at the junkyard There were no TPI cars but a bunch of V6 Fourthgens. I was thinking about getting the shroud and fans from a fourthgen.
Were the brackets really hard to make? Should I do what you did or just go and buy a set of aftermarket fans?
Old Oct 14, 2010 | 01:46 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
i have a set on my car, but i also have an LT1 and LT1 radiator. i had to trim around the gear box as well. i wired mine up using Nelson Performance's 3-relay wiring harness made for putting the fans in a truck. i re-wired it to switch on with the grounds instead of powers so the computer turns them on. always works and with a 160 stat, the car never really goes above 175.
Old Oct 19, 2010 | 10:46 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I have LS1 fans. I didnt have to trim them to clear the gear box I did trim them to slide into place. I put angled aluminum and riveted it to the top of the fan assy. Then slide that into the top lip of radiator. On the bottom I drilled 2 holes in the body. Slid bolts thru the fan assy thru the holes and nut on the bottom to tighten down and hold in place. works like a champ. just wired in another connector for fan inline with stock connector.
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
