Torque Converter Cover And Cooling
Old Jul 12, 2010 | 01:40 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I was looking on another forum and the discussion was about whether or not to run a torque converter cover. Some wanted to cut the ears off for more clearance and not use the cover.
Anyways this got me to thinking about those of us running a high stall torque converter and the cover. We all know that a high stall torque converter will increase the temperature of the transmission fluid and better cooling is needed with an add on transmission cooler.
For those of us using a cover my thought was to cut some holes in the front of the cover and the rear of the cover so some air will flow though the cover to aid in cooling. I would cover the holes with screen to keep debris out of the cover. Just wondering if anyone has some thoughts on the subject. I think I'm going to do it when Don is putting in my new motor.
Old Jul 12, 2010 | 02:12 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Torque Converter Cover And Cooling
doubt it would make any difference, It might draw out some heat but probably not going to cool any of the fluid down.
Old Jul 12, 2010 | 02:49 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I saw a cover in a Year One catalog that had some scoops on the bottom of it. Seemed like an interesting idea but I need all the ground clearance I can get and I can't justify spending $100 on something like that.
Old Jul 12, 2010 | 03:04 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
That thin plastic or metal dust shield is not holding any heat.
Old Jul 12, 2010 | 03:30 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
some cooler info here
https://www.thirdgen.org/forums/cool...on-cooler.html
Old Jul 12, 2010 | 03:48 PM
Car: 1989 GTA
Engine: 369 TPI
"That thin plastic or metal dust shield is not holding any heat."
Maybe not. I was just wondering if some air was flowing around the torque converter if that would be beneficial to some degree.
Thanks Gumby but I'm also a participant in the other post. I'm just mulling over the thought. I have a big transmission cooler on order.
Old Jul 12, 2010 | 03:55 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
letting air get to it might help but it there to keep dust n crap out
[AKA dust shield], if you only drive on nice paved roads, and won't be in snow, it probably won't hurt anything, will it help, dunno.
only a back to back test with a temp gauge will tell.
Though one thing is it would suck if a cat crawled up in there
Or say something on the road flys up in there, plastic bag, rope, old fan belt getting jammed up n wrapped up........
Old Jul 12, 2010 | 06:36 PM
Car: 1989 GTA
Engine: 369 TPI
"Or say something on the road flys up in there, plastic bag, rope, old fan belt getting jammed up n wrapped up........"
So true and that is why I was thinking of putting screens over the holes if I decide to do it.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
