Low Pro Fans
Old May 5, 2021 | 08:03 PM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
Low Pro Fans
What do you all recommend for a low profile fan setup. I gotta free some room up in that area. 91 Formula. BeCool direct fit radiator. Currently factory dual fans
Old May 6, 2021 | 10:33 PM
Swapper's Avatar
Re: Low Pro Fans
i run flex a lite dual fans on my turbo ls with a modified ebay radiator. seems to run cool so far. theyre one of the slimmest fan setups you can find.
Old May 7, 2021 | 10:22 AM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Low Pro Fans
Spal fans are pretty slim
Old May 8, 2021 | 12:31 AM
2slow5.0's Avatar
Car: 91 Formula
Re: Low Pro Fans
They look real nice. Part number by chance?
Old May 8, 2021 | 12:49 AM
Swapper's Avatar
Re: Low Pro Fans
i dont know exactly. sorry. i found them on craigslist. they ended up fitting perfect.
Old Jun 9, 2021 | 09:05 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: Low Pro Fans
Ive heard that the flexalite fans dont put out the advertised cfm numbers. I want to run them for space but I need better cfm fans with a t/a. I have an ebay 3 row rad,want to add a fan shroud and mostlikely the derale fans..should be able to vacuum the street at that point lol
Old Jun 9, 2021 | 11:31 PM
Swapper's Avatar
Re: Low Pro Fans
ive had this pretty much same setup on 2-3 turbo builds. never had any issues. usually only 1 fans runs even in 100+ degree weather.
Old Jun 13, 2021 | 07:10 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Low Pro Fans
16" Spal fan w/ homemade shroud. CFM is a little over 2k, but spal rates their fans with a load, as opposed to most others.
86White_T/A305
Nov 13, 2020 07:59 PM
Dora 9
Jul 28, 2013 11:39 PM
86firebird350
Feb 25, 2008 05:07 PM
355SS
Aug 4, 2003 10:26 AM
88Bravo
Oct 19, 2002 03:15 PM
