Cooling issue
Old Mar 10, 2024 | 08:13 PM
bholmes's Avatar
Cooling issue
Just completed the serpentine belt conversion! Car runs at 220 all the time with fan running all the time. Hose from heater core are hot, vs hoses from.radiator are cool to touch and as if no pressure on top hose! Any idea what could be my problem? Thermostat, water pump, or possibly belt routed wrong? Thermo and water were.bought new when I did the conversion! I k ow even though parts are new, can still be bad parts! My car is an 87 305, carb!!!
TIA
Old Mar 10, 2024 | 09:41 PM
Re: Cooling issue
Sounds like maybe the wrong water pump. What WP is on it?
Old Mar 11, 2024 | 08:46 PM
bholmes's Avatar
Re: Cooling issue
I ordered one for a 1988! I'll have to chk the partnumber and let you all know
Old Mar 11, 2024 | 09:22 PM
bholmes's Avatar
Re: Cooling issue
The part number I ordered is: GATES 43114
Old Mar 11, 2024 | 11:51 PM
Re: Cooling issue
What applications is it listed for?
Old Mar 12, 2024 | 01:03 AM
bholmes's Avatar
Re: Cooling issue
I double chk and it states "this part fits your car"! I'm gonna buy one from local parts store along with a thermostat
Old Mar 12, 2024 | 08:51 AM
bholmes's Avatar
Re: Cooling issue
Should I run the heater hose to the radiator instead of the waterpump like most serpentine set up are done! Just curious if that'd make a difference!
Old Mar 12, 2024 | 10:25 AM
Re: Cooling issue
Old Mar 12, 2024 | 10:39 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Re: Cooling issue
Looking up the part number on RockAuto, Gates 43114 is listed for a 1988. 1987 has a different part number. So, the water pump you have should be correct for a serpentine setup.
Are you running the backside (smooth side) of the belt over the water pump pulley?
Old Mar 12, 2024 | 12:00 PM
bholmes's Avatar
Re: Cooling issue
I've chk the routing multiple times, and it's right! Maybe an air pocket. Imma get a new pump from parts store and a thermo!
Old Mar 12, 2024 | 12:43 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: Cooling issue
An air pocket seems pretty unlikely....unless you simply didn't fill the system properly.
Old Mar 12, 2024 | 08:59 PM
bholmes's Avatar
Re: Cooling issue
Could someone send me the correct belt routing diagram. My car is an 87 305/carbed car. I converted to serpentine belts. I've found 2.different routing diagrams. Any help would.be greatly appreciated
Old Mar 12, 2024 | 09:37 PM
Car: '89 GTA
Engine: ZZ6TPI
Re: Cooling issue
Old Mar 12, 2024 | 09:53 PM
bholmes's Avatar
Re: Cooling issue
That's exactly how I have it routed! Imma change pump, thermostat and radiator/cap and see if that solves my problem
Old Mar 12, 2024 | 09:55 PM
bholmes's Avatar
Re: Cooling issue
What yr is that motor? According to diagrams I found , 88,89, 90 is different from 91,92
Old Mar 12, 2024 | 10:28 PM
Car: '89 GTA
Engine: ZZ6TPI
Re: Cooling issue
That is an 89’
Here’s a good thread discussing the different routings.
https://www.thirdgen.org/forums/tpi/...er-1992-a.html
Doesnt sound like that’s your issue though. Maybe the wrong water pump was in the package, or thermostat not working. Change both and go from there.
Old Mar 13, 2024 | 07:04 AM
bholmes's Avatar
Re: Cooling issue
I've got new parts ordered! Gonna try those and route belt different and go from there!
ANDYZ28
Jan 10, 2008 07:18 AM
IROCWPB
Jul 17, 2007 11:23 AM
anthony714
Mar 31, 2006 10:31 PM
D's89IROCZ
Mar 9, 2006 02:11 PM
david roush
Dec 6, 2003 09:12 PM
