ALDL interface for SD?
Old Jul 26, 2005 | 11:34 PM
ryan.h's Avatar
Has anyone successfully used the two transistor ALDL interface with the speed density computer?
http://www.andywhittaker.com/ecu/aldl_hardware_cont.htm
I just can't get the max232 one to work.
Old Jul 27, 2005 | 05:56 AM
honken's Avatar
Car: El camino 70 ss
Engine: corvette lt1 94
What car/ecm/tpi/tbi du you have.
Look at this site they say that works.
http://www.aldlcable.com/sc/pages.asp?id=24
Old Jul 27, 2005 | 09:24 AM
ryan.h's Avatar
91 speed density ecm ('730) TPI
it works at 8192 baud instead of 160 baud. I just wanna know if anybody else has used the 2 transistor one successfully.
Old Jul 28, 2005 | 09:07 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
I've had no problems using either type of cable on the '730.
What connection problems I have had, have normally turned out to be a problem with the laptop.
Old Jul 28, 2005 | 09:59 PM
ryan.h's Avatar
...such as?
Old Jul 28, 2005 | 10:25 PM
Dave_Jones's Avatar
Mostly OS-related, port settings either in windows or the bios. Sorry for not being more specific, but it's been a long time since I've had to work through those problems.
I had one old Compaq LTE that I could never get to do squat for scanning, unless brought up on a pure DOS boot.
Also had another old clunker that I think lacked full voltage to the serial port, it'd work with the extra 12V power plug attached to the max-232 cable.
Another Compaq that would work on a Windows boot to dos prompt, but not when running windows...never did get the serial port to work right with W98 running; and I'm not sure why. Never worried about it too much, since I had other laptops available -- that one ended up on my ECM bench and is mostly used for Moates' ECM program, which is DOS-based.
Other laptops have never given me any trouble at all with the same stuff. FWIW, the ones I've had no hassle with happened to be Panasonic and Digital brand machines.
Can you try a different computer?
Old Jul 29, 2005 | 04:05 PM
ryan.h's Avatar
Hmm. That's interesting. I'm running 98 too. I only have one laptop, unless a 100' serial cable would work...
I'll have to try some of these suggestions.
Old Aug 1, 2005 | 09:25 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
I'm working an issue with my 8192 setup with Tunerpro RT, Win98.
With the '165 160 baud datastream file, it shows connected on Com2, when in actuality it's not, whether hooked to vehicle or not, it shows it connected and monitoring, but no data. Allows me to record, etc., but no data.
If I change it to 8192 baud in the settings, I get "could not initialize port". If I change port back to Com1 (in tunerpro) then I just get the failed connection error.
I went into device mangler, and made sure that all the infrared junk was disabled. No setting for it in the BIOS I could find.
Haven't had a chance to try it on the vehicle yet, but with the cable now testing as "good" through tunerpro's test on the same Com port, I have high hopes.
xodus2002
Jul 17, 2020 09:08 AM
Veaceonee
Sep 29, 2016 08:15 PM
WejaZ28
Oct 3, 2015 07:38 PM
greenyone
Sep 8, 2015 08:41 PM
Gunsbee
Sep 7, 2015 07:10 PM
